No rear Sway bar!!!
Old Mar 4, 2006 | 01:48 PM
Thaniel's Avatar
No rear Sway bar!!!
Ok. I've had the car awhile and read a bit on the maxima org but I missed the fact that this car does NOT have a rear sway bar. Not Even the SE. Crappy if you ask me.
My '87 maxima had independant rear suspension AND a sway bar (although really small). The '95 doesn't have independant suspension and no sway bar. I think nissan forgot what Sports Edidtion means. Oh well.
I bought and aftermarket rear sway bar and put it on. It was only like $130 and it was worth EVERY PENNY. I highly recommend everyone get one.
Thaniel
Old Mar 4, 2006 | 01:53 PM
StillenIsaJoke's Avatar
What kind of sway bar did you get?
Old Mar 4, 2006 | 01:56 PM
JClaw's Avatar
That's funny because I have an article written in 1994 that states that the 1995 Maxima had the best handling on any stock maxima yet, better than all 1981-1994 model years, "minivan beam" or not.
Old Mar 4, 2006 | 02:17 PM
mxzmax's Avatar
umm SE stands for special edition not sports edition
Old Mar 4, 2006 | 02:18 PM
nismology's Avatar
+1 Outslalomed and outgripped them, with a stiffer frame to boot.
And just FYI, to the original poster, the rear beam DOES have a RSB built-in to it.
Old Mar 5, 2006 | 01:34 PM
Thaniel's Avatar
Originally Posted by nismology
+And just FYI, to the original poster, the rear beam DOES have a RSB built-in to it.
Uhhh....Where....Post a pic if yours has one. There isn't one from the factory. I checked the car. The FSM and a repair manual. NO REAR SWAY BAR.
Old Mar 5, 2006 | 01:37 PM
LudeAEM's Avatar
the beam acts as a sway bar for the most part
Old Mar 5, 2006 | 01:39 PM
Ninos_Maxima's Avatar
be the change u want2C
omg its a lurker!!!
Thaniel's Avatar
I went with the Cattman.
The bar mounts to the rear axle and then to the trailing arms instead of from the body to the trailing arms. This increases the unsprung weight which isn't desireable. I am not thrilled with the design but all the other rear sway bars for this model of maxima I saw forsale were the same but I can't argue with the results. When my wife even notices the handling change I know the change is significant.
Old Mar 5, 2006 | 01:46 PM
Thaniel's Avatar
Perhaps it got better times due to the wider tires on the '96. The 96 maxima (before I adde the rear sway bar) I have understeers way more than my '87 maxima. The '87 was much more balanced. Then again my '87 had the factory adjustable struts and I had them on full stiff. OH and the '87 came with a rear sway bar from the factory
Old Mar 5, 2006 | 02:24 PM
1996blackmax's Avatar
The guys are correct about the beam.
Old Mar 5, 2006 | 02:25 PM
Mishmosh's Avatar
A little excerpt:
Originally Posted by Sport Compact Car 11/98
So what is this "multi-link beam" and what makes it so great? In reality, every beam axle rear suspension must have some system of links to allow the wheels to travel up and down without moving front to back or side to side--the multi-link beam just does an exceptionally good job of it. Nissan's multi-link beam falls under the general category of a twist beam. Front-to-back location is accomplished with a single trailing link on each side that pivots where it attaches to the car, but is mounted solidly to the beam. This solid mounting of the trailing link to the beam means that if the wheels do not move together relative to the car--such as when the body rolls--the beam itself must twist to accomodate the different angles of the two trailing links. So in a twist beam, the beam itself acts as an anti-roll bar.
If the stock beam does not serve as an anti-roll bar, then neither do the aftermarket bars. All they are doing is stiffening the solid trailing arm attachment to the beam.
Old Mar 5, 2006 | 03:21 PM
Thaniel's Avatar
Where do you guys get this stuff.... PER the 2002 nissan brochure page 14
"GXE essential Maxima, SE sports edition, GLE, Luxury edition"
From 1998 Nissan Maxima brochure under SE "Sport-tuned suspension - Firmer springs, Front struts and rear shock absorbers; Liquid filled transverse link compression bushings; urethane front-suspension pivot busihings"
From the 2002 Maxima brochure. "SE the sportiest maxima: rear spoiler, fog lights, sport-tuned suspension, body color door handles, titanium tinted gauges and 17" alloy wheels and performance tires"
Call it what you want. The SE maxima's have the sport tuned suspension.
Oh another funny thing is the 1998 maxima brochure also states: "what makes maxima handle so well? to start, it's rear link beam suspension with and an innovative lateral link and control rod help keep the tires perpendicular for better tire-to-road contact. And front and rear stabalizer bars provide beter control during cornering and sudden lateral moves.
I am guessing the guy that wrote the brochure did not consult nissan's parts computer where it does not call out any rear stabalizer bars. Can't believe everything you read.
Old Mar 5, 2006 | 03:29 PM
Thaniel's Avatar
You don't have to believe me. Get an aftermarket bar. Put it on your car and drive it around some corners. They are pretty cheap and only take less than 30 min to install. It's night and day difference. A few years ago I put on some adjustable shocks on the back. It helped stiffen the rear but nothing close to what the sway bar did.
I purchased the bar in the first place based on the FAQ information on this board. Somewhere in there I read it was the first suspension mod that should be done.
I thought I'd help point this out to others as I had missed this tid bit of information myself and had wished I had know this years ago as I would have put the bar on then.
Old Mar 5, 2006 | 04:09 PM
Mishmosh's Avatar
I had an Addco bar for 5 years. It definitely does reduce body roll... but does so by stiffening what is already there--the twist beam. You cannot say it doesn't already have one if all you are doing is adding stiffness to the solid beam-trailing arm geometry.
Also, I have been a year with the Addco off. I don't miss it. I can corner just as well as I could with it. IIRC, the SMX nissan with Stillen RSB did the slalom slower than a stock max (Motortrend).
Old Mar 5, 2006 | 06:57 PM
96blackmaxSE's Avatar
boost me.....
umm SE stands for sports edition not special edition
lowpost99
Oct 26, 2025 06:53 PM
matts95max
Apr 23, 2025 10:44 AM
bbsitum
Sep 11, 2015 04:55 PM
flu2000
Sep 8, 2015 02:23 PM
