5th gen clutch, SS lines -- very satisfied
Old Mar 6, 2006 | 06:54 AM
d00df00d's Avatar
Old enuf to pick his own gears
5th gen clutch, SS line -- very satisfied
Just dropping a review.
I recently got my 5th gen clutch and pressure plate installed, along with a new throwout bearing, master cylinder, slave cylinder, and Techna-Fit stainless steel clutch line. I only have about 450 miles on it so far, but I like it a lot. The pedal is a little heavier than on my previous setup (stock lines, old hydraulics, 4th gen Exedy OEM replacement clutch), but it engages very smoothly and grabs more than hard enough (performance-wise, the car is bone stock).
The only sketchy thing is that it grabs really low -- almost on the floor. The hydraulics have definitely been bled, and I set the grab point as high as possible using the adjustment on the rod on the master cylinder. But, like I said, I only have 450 miles on it, so I guess I'll reserve judgment until it's finished breaking in.
Plus, the low grab point lets me shift faster.
Old Mar 6, 2006 | 08:45 AM
86maxima96's Avatar
I Broke OT
sounds great! i have a SS clutch line that i'm going to install this spring and see if it tightens up the feel at all. was install difficult, including the bleeding?
Old Mar 6, 2006 | 09:27 AM
MDeezy's Avatar
always great to hear a good review about my future setup
Old Mar 6, 2006 | 10:04 AM
d00df00d's Avatar
I have to give credit to Tilley (TILLEYS99 on the forums) for the labor.
Installing the line and bleeding the fluid were easy tasks, especially because we were replacing the slave cylinder at the time -- we just kept it within easy reach and bled it before installing it.
Old Mar 6, 2006 | 10:05 AM
d00df00d's Avatar
You're gonna run a 5th gen clutch on your VQ35 swap?
Old Mar 8, 2006 | 07:26 AM
d00df00d's Avatar
UPDATE: About 600 miles now, and bloody hell is this setup awesome! It grabbed super-low and felt kind of hard for the first little while, but it feels nicer and nicer every day. Pedal effort is just right, engagement is SUPER smooth and progressive, and grip is outstanding. As far as I'm concerned, it's absolutely perfect.
Old Mar 8, 2006 | 08:03 AM
moogotzskillz2's Avatar
How much did all that setup cost you, with the clutch lines and all except labor??
-moo
Old Mar 8, 2006 | 09:41 AM
d00df00d's Avatar
The clutch disc, pressure plate, throwout bearing, and line ended up being about $220 shipped. The master and slave cylinders were another ~$130 on top of that; I only got them because mine were busted.
Old Mar 8, 2006 | 10:17 AM
NissanMan97's Avatar
$220 shipped that sounds like a good price to me. Where did you go to get them? Local or online? Mine has 95k on it and is on its way so im going to do the 5th gen clutch setup because ive heard only good things about it.
Is the setup easy to install? Are there any modifications that need to be done? or is it a smooth replacement? thanks for the help
B
Old Mar 8, 2006 | 10:20 AM
aznsap's Avatar
wow, i should have gotten a 5th gen clutch instead of the act stage 1 when i did my 5spd conversion. oh well next time.
glad to hear the good stuff about this setup.
Old Mar 8, 2006 | 10:21 AM
d00df00d's Avatar
It's 100% plug-and-play. It's no harder than changing the clutch with 4th gen stuff. There is absolutely NO modification required.
I got everything but the line through DAVEB, and ordered the line directly from Techna-Fit.
Old Mar 8, 2006 | 10:41 AM
Maxpower96's Avatar
Hi glad you like it!!! I got mine done too and yes the friction point is like 1/3 from the floor. It was like 2/3 from the floor with my 4th gen setup. I had it installed in the same time as my 3.5 swap. It's been 200 miles and still happy with the setup.
Old Mar 8, 2006 | 10:50 AM
d00df00d's Avatar
You're using the 5th gen clutch with a 3.5?? Please tell me more about your setup! I am considering doing the same thing and I was wondering how well this clutch would hold.
Old Mar 8, 2006 | 10:59 AM
is DAVEB a member on the ORG or somethin?
B
Old Mar 8, 2006 | 11:02 AM
d00df00d's Avatar
Yes he is.
Old Mar 8, 2006 | 11:06 AM
thanks for the help, i will contact him and see if he can help me out.
B
Old Mar 8, 2006 | 07:56 PM
Maxedout5555's Avatar
To change the clutch do you have to take of the ypipe? Also how many hours should this take?
Thanks.
Old Mar 8, 2006 | 07:58 PM
d00df00d's Avatar
You're welcome.
Old Mar 8, 2006 | 08:00 PM
Matt93SE's Avatar
STFU n00b!
if you're asking those kind of questions, please pay someone else to change the clutch for you.
Old Mar 8, 2006 | 08:10 PM
Apparition's Avatar
Ichiban King
when you get a chance id like to talk to you about the swap.
Old Mar 9, 2006 | 12:46 PM
Maxpower96's Avatar
Hi apparition, i'm all ears
Old Mar 9, 2006 | 01:05 PM
RA030726's Avatar
I'm nutty for Nissans
its a good setup for bolt ons and longevity. i too think the pedal is rather stiff.
Old May 26, 2006 | 08:13 AM
meccanoble's Avatar
Sports Button FTW
i'm trying to change my clutch line but cant find quality instructions online, i have the ss line. Anyone know whats needed for this job? what tools? please help
lowpost99
Oct 26, 2025 06:53 PM
MAXSE5SPD
Sep 17, 2022 04:00 AM
boomerbrian
Oct 31, 2018 10:25 AM
BkGreen97
Apr 2, 2016 05:47 AM
Lowered_a33
Sep 1, 2015 07:49 PM
