How can I tell if my fuel pump is going bad?
Old May 25, 2006 | 12:09 PM
Dexter's Avatar
Does it throw somesort of code, or is it just a matter of whether or not your power/mileage is going bad?
Old May 25, 2006 | 12:51 PM
speed racer's Avatar
you can attach a guage between the fuel filter and the hose to see if the fuel pressure is within spec. If its low than you could change the fuel pump for preventive maintanence.
Old May 25, 2006 | 01:41 PM
pmohr's Avatar
No more Maximas...
It won't throw a code specifically for the fuel pump, there may be a code for excessively low fuel pressure but I don't believe there is.
Typically as fuel pumps go bad they get louder and louder until they finally just go kaput. Leave her running, and go take the backseat bottom cushion off (pops right off in a few seconds) and see if the fuel pump is very noisy. There should be some whirring or other quiet noises (after all, it is pumping fuel) but nothing very loud. If you can hear it easily with the rear seat cushion still on, then I'd replace it soon.
What makes you think your fuel pump may be going bad? Symptoms?
Old May 25, 2006 | 06:36 PM
darklegend06's Avatar
Good info!!! maybe sticky this if it already isn't.
Old May 25, 2006 | 09:50 PM
Dexter's Avatar
I can hear it whirring when I get close to the rear tire. I might go ahead and change it myself this weekend.
Old May 26, 2006 | 09:18 AM
alcatranz518's Avatar
The car will feel hesitant/ or struggle to increase speed. Also will make noise like pmohr said. Many times it will become louder as it dies and will not throw a code. But the best way to check IS by a Fuel pressure gauge. I check mine after or before the fuel filter, its the easiest spot. Keep in mind, the fuel pump does make a small whine.
BkGreen97
Apr 2, 2016 05:47 AM
homewrecker
Sep 23, 2015 03:41 AM
bumpypickle
Sep 20, 2015 08:22 AM
conansriver
Sep 11, 2015 10:26 AM
