Is napa gearlube recommanded for MT
Old Mar 6, 2006 | 07:25 PM
97green's Avatar
i recntly bought 99 se 5 SPD. i was wondering if can use napa gear lube. my plan is to flush the system. i im only gonna use keep it for a month or so. after that i might get redline and fill it up with that. did anybody out there use napa. how does it perform let me know. thank u
Old Mar 6, 2006 | 07:41 PM
MaximaSE96's Avatar
Maxima Owner
as long as its the right weight....GL4 75w-90.....it will be fine for normal driving
Old Mar 6, 2006 | 07:56 PM
97green's Avatar
its 80-90w . on the can it says gl3, gl4, gl5.
Old Mar 6, 2006 | 09:00 PM
PLUMMAXSE's Avatar
Stop
Do not use it. Only put GL-4 types in your 5 speed. Use redline or Amsoil or something that is made for trannys that specify gl-4 only. The max is one of them. Trust me, your 5 speed will shift much smoother and you won't destroy the metals in the tranny
Old Mar 6, 2006 | 09:14 PM
95CustomMaxima's Avatar
I would recommend going to Autozone and picking up 5 qts. of Pennzoil Synchromesh for about $6-7/qt. I switched out my Redline MT-90 for sychromesh and I am very pleased with the results. Synchromesh is also rated for GL-4 use.
-Nick
Old Mar 6, 2006 | 11:15 PM
Supermax95's Avatar
+1 for redline
Old Mar 7, 2006 | 04:40 AM
pratch's Avatar
Redline has a solid reputation in the Rx-7 world as well.
Consider this another +1 for Redline.
Old Mar 7, 2006 | 04:55 AM
MaximaSE96's Avatar
Maxima Owner
-Nick
U like the synchromesh better than the MT90....is it smoother??? i need to do a lube change and i was going to use MT90....
Old Mar 7, 2006 | 06:52 AM
4DRSpeed's Avatar
Project Ruby......
I had some cheap castrol GL3,GL4,GL5 lube in the transmission to hold me over for a little when I changed my axles out.
I finally bought some Amsoil GL4 and I am extremely happy with it. It is a ton better than that crap. It is silky smooth shifting gears. I highly recommend buying some Amsoil from talkinghorse in the group deal forums.
Old Mar 7, 2006 | 07:45 AM
shmad's Avatar
+1 for the amsoil. the tranny slides right into gears now. its like butter
Old Mar 7, 2006 | 08:47 AM
s0ber's Avatar
+1 for amsoil again.. it is clearly superior over Redline MT90...
BTW: I used napa 80w90 gl3-5 for a week after my 5spd swap, then amsoil came in.
Old Mar 7, 2006 | 09:11 AM
dgeesaman's Avatar
Maintenance Monster
Nissan says to use a 75w-90 GL-4. The gear oil I found on Napa's site is made by Valvoline and meets GL-3 thru GL-5 specs. It's probably fine to use, but if you want to be fussy I would recommend a 'true' GL-4.
Redline MT-90 is a synthetic GL-4 and it's excellent. Amsoil has their AGT gear oil that is a GL-4, but I haven't used it and that product page on their website is dead, so I can't comment on it.
A regular GL-5 (which is often the only option at the local store) can chemically attack the synchros in your tranny. Many gear lubes are rated GL-4 and GL-5 because they get GL-5 performance without being chemically aggressive. So if an oil meets GL-5 and GL-4, it's chemically fine.
But that leaves out one issue: lubricity - GL-5 is 'slicker' than GL-4, so the synchros will not get as much grip on the gears when you use a GL-5. As the synchros wear I would expect this becomes more influential. The result is balky shifting if the synchros can't grip the gears well, and if you're not careful (driver factor) you can wear the synchros, gears, and clutch sleeves very quickly.
Many people have used all kinds of gear oil, GL-4, GL4/GL5, GL-5 and had better/same/worse results. If it works for you, keep using it. But if you want to play the 'safe' road according to Nissan's recommendations, use a regular GL-4.
The GM Synchromesh fluid is a thinner oil than an 80w-90 or 75w-90, so I would avoid that unless you have shifting troubles when it's cold out. Once the transmission has warmed up, the GM fluid will simply be too thin.
Dave
Old Mar 7, 2006 | 07:00 PM
Supermax95's Avatar
i hope for tranni fluid not motor....ahh i crack myself up.
Old Mar 7, 2006 | 07:50 PM
ti2tmax's Avatar
Has his VINs memorized
where are good places to purchase these highly recommended oils?
Old Mar 7, 2006 | 10:09 PM
4DRSpeed's Avatar
Project Ruby......
012345
Old Mar 7, 2006 | 10:52 PM
Nealoc187's Avatar
SLOW
Dave
GM Synchromesh and Pennzoil Synchromesh are what I'm using in my built trans in my turbo car and I am happy with it, though I have not driven the car in extremely hot weather yet. I have of course driven the car in normal late fall weather (mid 70s to 80 degrees) at the track (transmission obviously fully warmed) and it has been great. It is what is recommended by the owner of my shop for use in all of our transmissions (Evo 5spd, Aisin Evo MR 6spd, DSM, Getrag 5 and 6spd, Toyota Aisin 6spd, etc (all of these are yellow metal synchro transmissions, of very similar synchro design to our maxima transmission which is also made by Aisin).
If I have a problem with it this summer I will definately report that fact and give an earful to Jon who recommended it's use (my boss and shop owner).
Be aware though GM synchromesh and pennzoil synchromesh does not actually have an API GL rating however, if it does it is not listed anywhere on the bottle.
iamute
Sep 20, 2015 05:22 PM
pjgreek
Sep 9, 2015 09:30 PM
boomerbrian
Sep 2, 2015 03:46 PM
follyburr
Aug 12, 2015 10:22 PM
