KONI Yellows
Old Mar 7, 2006 | 08:38 AM
MaximaSE96's Avatar
Maxima Owner
KONI Yellows
After doing a kwik search I was unable to come up with a answer to my question so here it is....has anybody installed Koni Yellows (I am sure there are).....but main question is was it a PITA so cut the old strut anf put the new Koni cartage in...or was it pretty simple...and any good instructions
Old Mar 7, 2006 | 09:12 AM
BlackCat's Avatar
RIP '98 Maxima SE
I had a shop do that chore of lopping off the top of the strut.
Old Mar 7, 2006 | 09:20 AM
MaximaSE96's Avatar
Maxima Owner
they say its easily done with a hack saw....if its jsut loppin it off to sepate the cartrage form the housing i can do it...does teh cartrage have anew shaft ???
Old Mar 7, 2006 | 09:58 AM
Fr33way™'s Avatar
Wild for Width
Are you not going coilovers anymore?
Old Mar 7, 2006 | 10:00 AM
Fr33way™'s Avatar
Wild for Width
IIRC JSutter and a couple of the third genners had a thread about this in the general forum not too long ago.
Old Mar 7, 2006 | 03:10 PM
RA030726's Avatar
I'm nutty for Nissans
im going to use 3rd gen inserts since they are 2" shorter and can handle up to 500 in/lb springs. only down side is that you cant just turn a **** to adjust them. i am very close to buying them but i have been collecting other parts 1st. i have stillen camber plates and GC coilovers so far.
as for cutting them up, its simple. any cutter will work, from a tubing cutter (like exhaust cutter) to a reciprocating saw. google koni install and you will find many sites.
Old Mar 7, 2006 | 03:33 PM
MaximaSE96's Avatar
Maxima Owner
i think my deal on coilovers might be falling thru the roof since i havent heard form the seller in a while after a few PMs....so I am just getting a back up plan together
Old Mar 7, 2006 | 04:22 PM
MaximaSE96's Avatar
Maxima Owner
well just read a few write-ups and seems pretty easy to do....i will go koni's if i have too
Old Mar 7, 2006 | 04:40 PM
Mishmosh's Avatar
Easy to do...just takes a little longer. If I were you, I'd get Illuminas instead...but that's just me.
Old Mar 7, 2006 | 04:43 PM
MaximaSE96's Avatar
Maxima Owner
Koni>Illuminas
Old Mar 7, 2006 | 06:38 PM
RA030726's Avatar
^^^hells yes! konis absolutely blow any other shock out of the water. .
Old Mar 7, 2006 | 06:39 PM
MaximaSE96's Avatar
Maxima Owner
are the rears jsut the complete strut
Old Mar 7, 2006 | 07:13 PM
CalsonicSE's Avatar
Yes, the Koni rears are a direct replacement, but in order to be adjusted they need to be taken off the car.
Old Mar 7, 2006 | 07:19 PM
MaximaSE96's Avatar
Maxima Owner
yea i was reading that....oh well...set is and be done anyway....maybe ill just go illuminas for rear...but prolly not cause i could careless i will just find an optimal setting and leave it...front adjustment is more important to me anyway
Old Mar 7, 2006 | 07:22 PM
nexgenmax's Avatar
R34
heard pipe cutter is the best to do this.
Old Mar 7, 2006 | 07:24 PM
MaximaSE96's Avatar
Maxima Owner
yea looks good...my buddy has one i can borrow....it should be intereasting...ill do a write up when i do it
Old Mar 7, 2006 | 07:32 PM
RA030726's Avatar
why konis are the ****! http://www.koni-na.com/presentations/civic/ http://www.koni-na.com/presentations/mustang/
Old Mar 7, 2006 | 07:38 PM
MaximaSE96's Avatar
Maxima Owner
u think it would be wise to get reds for rear or stick with yellows
Old Mar 8, 2006 | 03:38 PM
RA030726's Avatar
you cant get reds for the rear
Old Mar 8, 2006 | 05:05 PM
MaximaSE96's Avatar
Maxima Owner
well then.... i didnt even look.....anyway i am def going with Konis and prolly regular ol springs now....i got a letter from the IRS and i miscalculated my tax return so now Coilovers are definately out....i have to hold off on my Z Brake upgrade for a month or 2 and sacrafice 2 news tires for auto-x so instead of 4 i got toget 2.....THIS SUCKS
Old Mar 8, 2006 | 05:17 PM
super6's Avatar
did it on a freinds sentra, not hard at all
Old Mar 8, 2006 | 06:10 PM
BEJAY1's Avatar
Conecarver
Aside from inverting it for install, it's really only a 10min project to adjust em. If the rear's jacked, just loosen 3 bolts and off it comes.
Old Mar 8, 2006 | 06:44 PM
RA030726's Avatar
shucks, thats not cool.
you should pick up a set of used eibachs or GC c/o. too bad you sold the agx, since they are great for the money. i just picked up some used parts for dirt cheap compared to new. just keep you eye open.
im not sure what class you want to be in for auto x, but even stock springs with adjustable struts, sticky tires, and a RSB is a huge improvement over stock.
Old Mar 9, 2006 | 06:19 PM
MaximaSE96's Avatar
Maxima Owner
well i ordered some Progress Springs...since i am ona tight budget now and cant get Coilovers i made a Compromise with pretty decent handling,drop, price, and somewhat decent ride of the Progress Springs....and but still going with Koni Yellows....there is one thing i couldnt find were spring rates for them...anyone know...and Sutter i have budgeted for the Z brakes and i will end up being in STX....i havent heard much talk of Koni Yellows with Progress...maybe this will turn out to be a nice combo....maybe next year i can get some coilovers...or upgrade to Custom Rated GCs
Old Mar 10, 2006 | 08:11 AM
sergofast's Avatar
fwi. It is well worth the time to install these. I have had the koni reds and absolutly love them. koni yellows are supposed to be even better.
Old Mar 10, 2006 | 08:49 AM
MaximaSE96's Avatar
Maxima Owner
yea i am def doing the yellows......and am just wondering about the springs now.....i personally think they are one of the most underrated springs for 4th gens....anybody know their rates
Old Mar 10, 2006 | 12:58 PM
RA030726's Avatar
i dont know the rates for progress, i asume they are less than eibach, but higher than the s techs. make sure you trim the bump stops enough (maybe even drill some holes in them to make them softer) and think about trimming the koni insert for more travel. maybe get some rear mounts used to save a few bux.
Old Mar 10, 2006 | 01:05 PM
MaximaSE96's Avatar
Maxima Owner
I assume they are a little softer...i just hope not too much....i will definately trim bump stops..u think its better to go with the one piece bump/boot or separate stops and boots...how would i trim the insert
Old Mar 10, 2006 | 04:09 PM
RA030726's Avatar
just stick with the stock bumps/boots that you have. trimming the insert is time consuming, but basically you just cut some of the threaded part on the bottom off. there are many ways to do it to i wont get into detail on them. it ranges from welding to just the use of washers.
http://www.sr20forum.com/showthread....koni+shortened
Old Mar 10, 2006 | 07:47 PM
MaximaSE96's Avatar
Maxima Owner
even if the dust boots are shot...they are a lil tore up
Old Mar 11, 2006 | 05:40 AM
RA030726's Avatar
get some new dust boots if they are really torn up. i used rancho boots from VIP. they are similar to the rear boot in size, but will fit on the front with minimal effort. they are like $3 each. i had the kyb boots but they ripped quicker than stock, so i have stayed away from them.
Old Mar 11, 2006 | 11:50 AM
AMG NMY's Avatar
All I know is that people who installed KONIS are very happy with them.
Old Mar 11, 2006 | 02:42 PM
MaximaSE96's Avatar
Maxima Owner
there are very few people here with them.....i am excited.....now i am pissed because i my mom fronted me money to get all the stuff for my car so I COULD go coilovers but i am not because my springs arrived today and ordring KONIs monday....and ill have to get boots....and i can now do my brakes YAY
Old Mar 11, 2006 | 03:37 PM
RA030726's Avatar
ill have the 3rd gen inserts, for the front soon. ill install them along with my stillen camber plates. i may get b14/b15/p11 rear struts as they are 1" shorter. couple all this with my GC coilovers and bens rear mounts. its should be pretty sweet.
Old Mar 11, 2006 | 08:43 PM
MaximaSE96's Avatar
Maxima Owner
how will the 1" shortness effect travel...will it help hurt.....Sutter you should come up to Toronto for track day with me on June 16th
Old Mar 12, 2006 | 09:43 AM
RA030726's Avatar
it depends on what spring you are using. with the GC i wont have to drop the collar to lower the rear of car, which will help keep most of the amount travel. if you pair them with a regular drop spring the car will be 1" lower in the rear, and may have even less travel than with the original strut.
as for using the storter insert up front, its a big plus with the use of any drop spring or sleeve coilover.
Old Mar 12, 2006 | 03:29 PM
MaximaSE96's Avatar
Maxima Owner
let me know exachty what mods are needed to het 3rd gen fronts to work when u do it
Old Mar 12, 2006 | 06:38 PM
RA030726's Avatar
sure thing
Old Mar 12, 2006 | 07:01 PM
MaximaSE96's Avatar
Maxima Owner
sweetness....if it nots too much i will have to do it
doctorpullit
Jul 20, 2019 09:31 PM
AcuraLegend
Oct 17, 2016 08:47 PM
Fbana41
Aug 29, 2016 12:18 PM
AcuraLegend
Sep 22, 2015 04:22 PM
Colossus
Sep 9, 2015 05:46 AM
