Headlight problems.. please try and help.
Old Mar 7, 2006 | 08:45 PM
ShRapNeR's Avatar
got in my car tonight.. started down the road, and realized my lights weren't on.. put them on bright and they worked fine..
so they don't work, anyway changed the headlight bulbs, the right one still dosen't work on dim, but yet the driver side does..
i havn't had a chance to check the wiring, but could someone please let me know if you've had this problem, and what you did to fix it.
Old Mar 8, 2006 | 12:50 AM
dblair's Avatar
My girlfriend's 3rd gen had same issue (both high beems worked but only one low beem worked). In her case it was the headlight switch that was bad (the stalk on the steering column). I picked up a new one at the dealer for around $50.00 and replaced it and it's been fine ever since. It was cheap and easy to fix.
Old Mar 8, 2006 | 12:59 AM
darklegend06's Avatar
my sister's 99 max has the same issue, but it seems there is a bad wire on one side. I'm planning on fixing it but I haven't had time.
You got two choices right now:
1 headlight stalk
2 wiring
Old Mar 8, 2006 | 10:11 AM
Digitized's Avatar
I had the same issue ( 1 headlight works ,both highbeam works)..
I had a problem with the OEm headlight stalk... a buddy of mine "re-wired it.. now it works no problem, but I just don't have DRL's ..
Old Mar 8, 2006 | 11:45 AM
95mtlMAXSE's Avatar
shift_Puff
514 have a good Trip to toronto
Old Mar 11, 2006 | 02:23 PM
mechanicaljoint's Avatar
did you check the fuses? not sure how the hi/lo is wired and how many fuses there are...
Old Mar 11, 2006 | 03:48 PM
Batxel's Avatar
blah
it doesn't sound like a fuse issue because the fuses are setup for right and left. So if say the fuse for your driverside headlight blows then both the low and hi beam will be out on that side.
Old Mar 11, 2006 | 04:09 PM
Dodd's Avatar
I had a similar problem with mine,, i let my friend take a look and he said that one of the wires was damaged and a fuse was blow.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
