Udp Users Enter!!
Old Mar 7, 2006 | 10:15 PM
willkim's Avatar
Udp Users Enter!!
'99 Max with motostorm udp.
install went pretty smooth but i have a couple questions
1. The pulley's starting to make a noise. Kindofa metal on metal rubbing sound that increases frequency with rpm. not real harsh, but noticeable when the radio is off. Driveability is fine, no noticeable difference, except the increase in power. should i reinstall the pulley? maybe i didn't get it flush... but i tightened to the correct spec torque. any ideas?
2. the idle pulley tension adjuster (located directly to the passenger side of the engine block, accessed from the top.) doesn't seem to be adjusting the tension at all. When fully tightened (turned the nut clockwise) the bolt is not visible and the nut seems flush with the frame. however when the nut is fully loosened (counterclockwise) the bolt seems to stay in the same place and the nut lowers itself closer to the pulley. This results in no difference in tension for the belt.
Am i right in thinking that the tension adjuster NUT should stay put, and the bolt (along with the pulley) should be the one moving up and down? right now it seems like the pulley isn't even moving and just the nut is moving up and down.
or am i just completely off base here...?
sorry for the long post just wanted to be clear since i have no camera/pics readiliy available.
Old Mar 8, 2006 | 07:09 AM
icedout's Avatar
well i will tell you one thing for sure you shouldent be getting any metal on metal noise...i would double check the udp and make sure you did it right.
Old Mar 8, 2006 | 07:33 AM
TNmax24's Avatar
did you replace the seal
Old Mar 8, 2006 | 09:28 AM
Xmax's Avatar
Belt might be slipping, you might need more tension on the belt. Also are you still using your old belts, or are you using the recomended belt sizes that the instructions asked you to get.
Old Mar 8, 2006 | 10:06 AM
recardeeps222's Avatar
bad mama jama
i have the same udp on the same model year max, and the only thing i've noticed since install is some squealing when i turn the car on but it goes away when it warms up.
I don't really understand what you saying about the tension bolt, but yeah, what he ^^^ said, metal on metal is bad.
Old Mar 8, 2006 | 10:20 AM
willkim's Avatar
thanks for the comments. i do realize that i shouldn't be getting this noise... which is why i'm asking for help.
i did replace the seal. and i did replace the belts with the recommended sizes.
any ideas on the idle tensioner? i want to reinstall the pulley, but will find it difficult if i can't loosen that belt. i'll try to get pictures, so you guys can figure out what i'm talkin about.
please help.
will
Old Mar 8, 2006 | 11:26 AM
aznsap's Avatar
if i remember correctly, the tensioner should move up and down. from the top of the car, if you're turning it and seeing it move down, it should be tightening the belts.
Old Mar 9, 2006 | 02:51 AM
willkim's Avatar
thanks for the help guys...
me and my bro fixed it... turns out the idle pulley tensioner was broken and the belt needed some major adjustment. but we got the parts replaced and all is well... noise is gone. she's back to normal. thanks again!
Old Mar 9, 2006 | 03:10 AM
ti2tmax's Avatar
Has his VINs memorized
When I first did mine, there was a noticable noise that all my friends thought should not be there. Just the other day I got a smaller belt to bypass my AC and the car is stock quiet now.
litch
123
Jan 4, 2024 07:01 PM
James92SE
142
Jan 2, 2024 09:23 AM
JonBlz
Oct 5, 2015 06:02 PM
