Quick Answer Needed (Timing Advance via Consult II)
Old Mar 10, 2006 | 02:31 PM
Dubbya's Avatar
VK56 Inside
Is this possible for 4th gen ECU's?
Related Link for 5th gens.
http://forums.maxima.org/printthread.php?t=383168&pp=40
Old Mar 10, 2006 | 05:12 PM
Mxrider52's Avatar
I support for what?
hmm interesting someone chime in
Old Mar 10, 2006 | 05:26 PM
9378max's Avatar
i believe this would work for a 4th gen but its worthless because the ecu would just go back to normal again unlike in the 5th gen.
Old Mar 10, 2006 | 05:37 PM
Trajiksmax's Avatar
Proud Maxima Owner
The ignition timing is controlled by the ECM to maintain the best
air-fuel ratio for every running condition of the engine.
The ignition timing data is stored in the ECM. The ECM detects information such as the injection pulse width and
camshaft position sensor signal. Responding to this information,
ignition signals are transmitted to the power transistor.
The ignition timing is revised by the ECM according to the other data stored in the ECM.
1 At starting
2 During warm-up
3 At idle
4 Hot engine operation
5 At acceleration
NOTE: IGNITION TIMING IS NON-ADJUSTABLE
Old Mar 10, 2006 | 10:08 PM
Nealoc187's Avatar
SLOW
Consult 2 can advance the timing while it is plugged in, but when disconnected the timing will revert to whatever it is set at on the ECU. So unless you're going to steal a Consult 2 it's not really gonna work.
Old Mar 13, 2006 | 07:16 AM
Dubbya's Avatar
VK56 Inside
Aight guys. Thanks for the info.
LilVito
Oct 25, 2019 08:12 AM
Ben2003GLE
31
Jul 17, 2016 08:13 AM
smplyamzng
Dec 13, 2015 01:19 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
TonyJr
Aug 20, 2015 12:14 AM
