Okay, 300zx wheel guys
Has anyone run 300zx TT wheels? I found a guy who's selling his wheels and tires for really cheap locally. It would be awesome to get this for awhile and then somehow pick up another set of rear wheels and be running 16*8.5 all around.
Will I be able to run these wheels and tires? Would I need spacers? How about for the front? I need new wheels soon and have been obsessing about it, but I think that if these wheels will work (even if I need some expensive spacers) it'll be worth getting them and then upgrading my fronts later.
Again, does anyone have experience with 16*8.5 300zx wheels on your max?
ehh, the rears may be fine. But I can see the fronts being bowlegeged. The 7.5" fronts are pretty much as wide as you want to go. Those 8.5" wheels have the 35mm offset you may have a problem with clipping the tires under hard turns or bumps. My rears could use a 5 or 15mm spacer but its not a big deal now, They fit better than the sawblades. Hope that helps
maxfever1987
Nov 19, 2016 08:01 PM
