NGK Iridium
Old Mar 16, 2006 | 11:48 AM
metal_god98SE's Avatar
NGK Iridium
Anyone using the NGK Iridium plugs in their Max? Any pros/cons over the Platinum spark plugs?
Old Mar 16, 2006 | 12:07 PM
tavarish's Avatar
fwd gone rwd cr00
I have NGK Iridiums in my parts maxima, i'm thinking of using the slighty used Iridiums over my fairly new Champion Coppers in my daily driver...i replaced my NGK coppers because they were black as night.
If they're much better, i'll just use the iridiums.
Old Mar 16, 2006 | 04:57 PM
maxunknown's Avatar
plugs
only ngk plats
Old Mar 16, 2006 | 05:25 PM
NYC32798's Avatar
I have NGK Iridiums in my 96. It did idle a bit smoother when I put them in but then again my old plugs were shot. Didn't really notice anything as far as hp gains. Just ran smoother. Plus they are cheaper than the OEM platinum plugs.
Old Mar 16, 2006 | 05:49 PM
99grnmaxgxe's Avatar
Are you sure they are cheaper than the NGK Platinums? I thougth Iriduims were like the most expensive?
Old Mar 16, 2006 | 05:53 PM
Z-CARR's Avatar
The OEM NGK Platinums are the best plugs for the Maxima.
Not to threadjack, but where is the link to search this site for info? Also, I can't start a new thread. Why? Thanks.
Old Mar 16, 2006 | 05:55 PM
You have to donate to use the search function, you cannot start a new thread until you have 15 posts.
Old Mar 16, 2006 | 05:58 PM
Z-CARR's Avatar
Thanks for the info.
Old Mar 16, 2006 | 08:05 PM
Mymax97's Avatar
Hi
I use them and i love them. But im also boosted and it really serves no purpose to have iridiums n/a from what im told.
Old Mar 17, 2006 | 07:33 AM
Feed's Avatar
Iridium plugs, pound for pound, are a better value than a platinum plug of similar design. Iridium is a precious metal that has seen use in sparkplugs for some time now; however, the technonolgy used to bond iridium to a spark plug electrode in mass production has only recently become economical.
In a nutshell, iridium conducts a charge more efficiently than platinum; less iridium needs to be used compared to platinum, meaning the electrode tip is significantly smaller. Although iridium is a more expensive material than platinum, the iridium plug is cheaper because such little iridium material is used.
Take your pic - if you're a die-hard platinum user, you're not missing anything with iridiums. However, if you want to "save" a few dollars go with the iridiums. Iridiums will see wide-spread usage in the next few years (I think). Do they "perform" better? I don't believe the effect is substantial. Are they more economical compared to a platinum? Yes.
Excalibur23
Oct 13, 2015 04:33 PM
msellas
Sep 23, 2015 09:16 PM
evonder73
Sep 1, 2015 02:21 PM
maxinout93
Aug 20, 2015 02:17 AM
Turbobink
Aug 15, 2015 07:20 AM
