Problem With my Max
Old Mar 19, 2006 | 02:23 AM
ghostman1000x's Avatar
Problem With my Max
Today I was getting on the highway and had to pnch the throttle to get in front of some jerkoff but when I punched it there was no reaction for almost to or 3 seconds then it took off like normal.I notice it is been hesitating in power when I drive it normal.It don't feel like the tranny and the fluid is good.Some people suggested to me the egr or the fuel filter.What are your opinions?
Old Mar 19, 2006 | 05:13 AM
Maxima880's Avatar
First thing you need to do is check for codes in the ECU. There are a lot of sensors that affect power. Apart from that, how many miles does it have, hows it start, hows the idle? When did you last change plugs, filters?
Old Mar 19, 2006 | 08:53 PM
its a 98 with 105k.Sometimes when I start it(cold start) the rpms go down like its gonna die to 100-200 rpms and bounces back up to normal sometimes it has died and It usually has a sweaky noise coming from the belts but the belts are good.
Old Mar 20, 2006 | 04:45 AM
njmaxseltd's Avatar
Clean your throttle body and IACV to correct your morning start.
The Maxima transmission is not the fastest reacting tranny. Depending on what speed you were at when you "punched" it, it probably just didn't down shift very fast.
I suspect the delay you felt was normal.
Old Mar 20, 2006 | 09:25 AM
clive's Avatar
100% chingon
Agreed. There seem to be 'certain speeds' that affect this. Sometimes if I happen to be doing the 'wrong' speed when I hit the loud pedal, there's a delay, then it shifts down, the revs are pretty high, then it quickly shifts up again. As if the tranny is saying to itself, "Oh! Do I *really* have to downshift at this speed? Oh well, OK . . . . . There, see!? Too many RPM, so I am going to shift back up again..."
Old Mar 21, 2006 | 11:38 PM
So I takes a whole 2-3 seconds to react?That seems kinda dangerous if u need to pass a car and the car won't get up.Luckily the truck that I had to pass was a 4cyl ranger
Old Mar 25, 2006 | 06:04 PM
99maxeclipsemtx's Avatar
i replaced my fuel filter and i guess it does it less but still will hesitate once in a while i've heard coil packs could be the problem aslo what kind of fuel are you runnin your supposed to use 91 or higher
Old Mar 25, 2006 | 09:42 PM
whitegold's Avatar
Well you can still pass a car without flooring it.. youll pick up just fine and not worry about downshifting.
Old Mar 25, 2006 | 09:45 PM
aih98max's Avatar
scoobystoned...
my car has 134K. its an auto. it picks right up when i nail it. clean the tb and IVAC. i did that a few thousand miles ago, cuz my car did the same cold start thing. now it runs like a dream more responsive too.
matts95max
Apr 23, 2025 10:44 AM
pktaske
May 6, 2016 07:49 AM
captchaos
Mar 15, 2016 12:18 PM
MaxLife17
Sep 8, 2015 02:36 PM
pktaske
Sep 4, 2015 08:40 AM
