Guys help how hard to replace rear wheel bearing
Old Mar 20, 2006 | 11:26 AM
black97's Avatar
How much it worth for 1 bearing or there is two?
Can i do it myself what tools do i need.
I think it's a bearing because when car is moving i hear knocking sound coming from rear right side so today i checked it and when i woble it it seems like there is a little space and a wheel knocking a little.
What do you think, am i able to do it myself.(a little inf. about myself replaced alternator, oil changes, antifreeze filters spark plugs coils)lol
What do you think guys autoshop or myself.
Old Mar 20, 2006 | 07:05 PM
black97's Avatar
really need help guys ASAP
Old Mar 20, 2006 | 07:14 PM
nyp083's Avatar
i heard that sound coming from my front right and i tightened all of my lugs then it went away
Old Mar 21, 2006 | 11:22 PM
black97's Avatar
bump
Old Mar 22, 2006 | 12:39 AM
darrick's Avatar
Dallas Nissan Enthusiast
i think i have this problem to I have tryed everything to fix this sound i get from the rear pas side wheel i can hear it mostly when turning
Old Mar 22, 2006 | 04:14 PM
darrick's Avatar
bump for anyone who knows anything about this
Old Mar 22, 2006 | 04:27 PM
black97's Avatar
Yea thats ****ty man i have tried everyting today basicly all day spent and what i'm gettin. At first i regrease this wheel bearing then i went for a ride sound still there but only on bumps so i thought that might be something i my trunk(right now it's all aparted) i've remooved everything but unforunately sound is still there i thinking tht it's not a bearing. May be one damn nut untighten somewhere and makes that sound.
Old Mar 22, 2006 | 05:00 PM
DR-Max's Avatar
Sounds like the wheel bearing alright! If the noise is there especially when you turn it is definitely the wheel bearing. What happens is that when you turn left or right, the weight of the vehicle shifts to the opposite side. The wheel bearing on that side sustains that weight and if it is bad it will make that sound you keep hearing. Wheel play is also a symptom of bad bearings. Replacing the bearings is a PITA. Removal of the wheel hub shouldn't be that difficult. What most do is they take the wheel hub to a shop to have them remove the old bearings and press on a new one.
Old Mar 22, 2006 | 05:03 PM
Timz96SE's Avatar
You need to take the caliper of to the side and rotor. Than I think you need a 32MM socket and a rachet with a pipe over it to help you loosen it. I have the same problem it is the bearing. But you have to replace the Hub. Its all one piece.
Old Mar 25, 2006 | 05:49 PM
99maxeclipsemtx's Avatar
allright i went to a pick it yourself yard and bought the bearing for 12 dollars it's the bearing and the hub as a unit it costs 90 dollars at an auto parts store the bearing is like 30 dollars alone. i bought the bearing and was going to go the same route you went and i bought 2 different bearings and they were the wrong size so make sure you bring the hub in to match it up first. putting it on is easy take off the wheel brake caliper dust cap for center axel nut. take the bolt off and thats it make sure you torque it to specs the specs are in the haynes if you didn't know
Huttig2009
Sep 25, 2015 03:31 PM
stromm
Aug 27, 2015 04:13 PM
Flores94
Aug 11, 2015 12:53 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
laparka66
Aug 6, 2015 09:36 AM
