auto transmission ground
Old Mar 21, 2006 | 01:33 PM
aih98max's Avatar
scoobystoned...
could somebody post a picture of where the tranny ground is on an auto? mines a 98 but im sure its the same for all 4th gens. also, if anyone has a link to a good grounding kit write up or diagram, please let me know. im building my own grounding kit, already got some grounds, but need more including tranny, but i dont know where it is. thanks.
Old Mar 21, 2006 | 01:35 PM
Kevlo911's Avatar
Kevlo for President
I dont think the tranny has its own ground but I added one there.
Old Mar 21, 2006 | 01:41 PM
aih98max's Avatar
scoobystoned...
did you just bolt a ground onto the tranny or what? ive heard people say the tranny has its own, and if you add it to your grounding system the auto tranny will shift better.
Old Mar 21, 2006 | 01:48 PM
f550maranello2's Avatar
i think it does.. its on the drivers side near the wheel welll.....
Old Mar 21, 2006 | 02:05 PM
Kevlo911's Avatar
Kevlo for President
I just chose a bolt and added a wire there.
Old Mar 21, 2006 | 03:20 PM
aih98max's Avatar
scoobystoned...
anybody got a pic of the tranny ground?
Old Mar 21, 2006 | 04:25 PM
White Shadow's Avatar
Still chugging along...
I dont have a pic but it does indeed have it's own ground and upgrading it WILL make quite a noticeable difference in its performance immediately. The ground is a 12 GA black wire about a foot or so long that runs from a bolt on the driver side housing to a point on the chassis about 6" behind the driver side motor mount. I have a CAI so it's very easy to get to but if you don't it will help to remove the factory air intake and the spashguard under the radiator/engine. I replaced it with a 4 GA audio power cable with ring terminals. Shift is much smooter, particularly the harsh 1-2 shift, and the tranny seems much more responsive to the throttle than before. It may be my imagination but it also seems to hold high RPM's just a little bit longer before upshifting during full throttle acceleration. Hope this helps.
Old Mar 22, 2006 | 05:45 AM
Juicey's Avatar
This ORG has saved me $$$$$$$$
I have two links for you:
Shows pictures of where people grounded...I think on the 7th or 8th page.
http://forums.maxima.org/showthread.php?t=452286
Discussion oh how grounding improves performance, if at all:
http://www.tprmag.com/issue/8/8_elec_stab.shtml
I plan on running ground wires to starter and tranny when it gets warmer.
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
