Compression Check Help/Info?
Old Mar 23, 2006 | 02:40 PM
danman700's Avatar
I've got 160k on my motor, so I figured I should do a compression check, i manged to come upon a compression tester for the evening but I am not quite sure how this will work. So far my basic knowledge is you take out the coil pack and the plug, put this thing in there and start it up? read the number and thats it, does anyone have actual instructions or anything about how to check your compression, is that the right method? Also what should the numbers read? I know each cylinder should be close to the rest but how close? Thanks in advance
Old Mar 23, 2006 | 05:41 PM
danman700's Avatar
bump....someone please i gota figure this out
Old Mar 23, 2006 | 06:03 PM
PLUMMAXSE's Avatar
Compression on the VQ is 185 psi per cylinder-Standard!
142 psi minimum and
14 psi difference between cylinders
From Chilton's manual use a screw-type compression gauge for your readings!!
Old Mar 25, 2006 | 05:32 PM
99maxeclipsemtx's Avatar
i took an engine class back at school, and your definetly right the compression figures should be close so you know the engine is balanced i mean so you dont have like one cylinder with a bad ring or clogged with sludge preventing oil to the cylinder walls
aw11power
Oct 10, 2021 04:57 AM
maxinout93
Oct 31, 2015 02:04 AM
salty318
Sep 29, 2015 01:21 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
