changed knock sensor
Old Mar 23, 2006 | 05:47 PM
Litowcas's Avatar
i just changed my knock sensor.. however did not reset the ecu.... went to autozone and bad knock sensor code still came on.... is this normal or shoudve the code disapear w/o reseting the ecu?
Old Mar 23, 2006 | 05:54 PM
erty67's Avatar
Decal Specialist
i think you need to reset it
Old Mar 23, 2006 | 08:18 PM
darklegend06's Avatar
I heard you have to drive like 200miles or so for the code to go away. But faster if you just reset it yourself.
Old Mar 24, 2006 | 05:12 AM
bmiller95max's Avatar
yeah...just reset the ecu
Old Mar 24, 2006 | 07:11 AM
Fido Auto's Avatar
it definately has to be reset
Old Mar 24, 2006 | 10:53 AM
nismos14's Avatar
§è~® f®ÈÄk
Replace the knock sensor again that should help.
Old Mar 24, 2006 | 04:02 PM
mindlessoath's Avatar
i unplugged the battery before doing the repair. removed the old, replaced the new.
dont forget to clean the ground wire that connects to the engine. dont forget to not tighten it to tight.
i plugged my battery back in and it worked fine, no more code.
reset the ecu if yours is messing up and then it should work fine.... assuming there isnt something else wrong... use a multimeter to test the actuall wire - this will let you know if somethings wrong with something else.
Old Mar 24, 2006 | 07:51 PM
maximaman10's Avatar
You have to reset the ECU to clear the code for a clean start.
bbsitum
Sep 6, 2019 07:31 PM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
