quick question about fuses.......
Old Mar 24, 2006 | 09:36 AM
RicoSuave98's Avatar
so i blew my fuse for my park lights, but i don't know what fuse it is. the panel map is hella confussing and i can't find my damn test light. does anyone know what number the park lights are? thanks so much
Old Mar 24, 2006 | 10:06 AM
chillin014's Avatar
what is so confusing about the map?...
Old Mar 24, 2006 | 10:10 AM
Greeny's Avatar
¯\(°_o)/¯
Just pull the fuses one at a time from top to bottom until you find the blown fuse...
Old Mar 24, 2006 | 10:17 AM
i don't know but it doesn't make sense to me. there are fuses in places that have holes in the map and there are too many fuses in some columns. and i would pull them all but my fuse puller is with my test light that i can't find so i've been using so clip i have and its a real pain in the ***
Old Mar 24, 2006 | 10:23 AM
also i don't know what they're called on the map. i've pulled every fuse that has "lights" in the name and they are all good
Old Mar 24, 2006 | 10:31 AM
chillin014's Avatar
bro, some of the fuses are spares, and such. you can get the general idea by observing the pattern.
just drive down to autozone and pick up one of those little picker/tester thigns for like a couple bucks.
Old Mar 24, 2006 | 10:33 AM
chillin014's Avatar
how.....did you get the valve cover that color, that is gorgeous.
Old Mar 24, 2006 | 10:42 AM
Greeny's Avatar
¯\(°_o)/¯
Several coats of teh rattle can,and clear coats....Cost me about $10...And a day of painting..
Old Mar 24, 2006 | 01:06 PM
ok so back to my problem since i've found my test light now and half of the fuses don't yield a light. and i know they're not blown cuz i have used them and they work. so will someone that is knowledgable about the fuses lend me a hand
Old Mar 24, 2006 | 01:23 PM
chillin014's Avatar
Sry doublr post
chillin014's Avatar
Are you sure you actually made contact with both of the metal parts. Some of them are hard to get to and I know I've thought I was making contact a couple times when I wasn't. Try switching some around that you know do work and seeing if they work in the spot of the non working one.
Old Mar 27, 2006 | 03:50 PM
99maxeclipsemtx's Avatar
check the p-light bulbs if you rewired them or even if you didnt they could be bad also look in your owners guide or the wiring diagram in the haynes or chiltons manual which you had better have allready
Mar 12, 2020 12:06 AM
pears
Sep 18, 2015 05:25 AM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
Johnny9595
Sep 3, 2015 05:18 AM
