Look what came in the mail today...
Originally Posted by chillin014
is that the 350z upper manifold? isnt that a pretty difficult install. has anyone even dynoed with that yet?
fwd gone rwd cr00
it's a 350z intake manifold (upper, mid, and lower). It's a direct bolt on to the 3.5 i'm putting in my car. it should give gains all throughout the powerband, but it's hard to say, because no one's ever dynoed on one of these on a 4th gen before.
And MDeezy, i'm gonna run with the 5/16" plenum spacer as well. I'm going to cut my hood and put either a scoop or a bulge in its place.
Should be a good summer.
Damn you...I thought you were installing in the summer? Ahh well, keep us posted on your 3.5 progress.
Did you decide that the 3.5 swap was easier than getting that spark plug boot out... (I've been off the .org for a couple of days...I don't know if you resovled that, and I know you've been planning on that for a while.)
Originally Posted by Akumachan
Just cut a hole and leave the manifold sticking out like an old school super charger, but not nearly as cool looking.
I know this setup hasnt been dynoed yet, but the gains are definitely there. Dropping the pedal at the on-ramp and hitting 130mph in no time is good enough of a butt dyno to me!!
Originally Posted by tavarish
Hey, mailman just dropped off this jem for me today.
[IMG]http://i4.photobucket.com/albums/y120/tavarish/Car%20pics/350z.jpg[IMG]
Doing the 3.5 swap in about 2 weeks, putting this on at the same time.
fwd gone rwd cr00
Originally Posted by Nismo3112
You doing it Vsa's way or my way?
if i did it your way and got the spacer, i would still have to cut the hood.
I'll look at the dyno #'s, and if you're ahead by alot, i'll consider doing it your way...
What i really want, thought, is the 300hp plenum, I can definitely see some gains there. What is is called, the MREV?
By the way, what clutch did you use for your swap? I'm leaning towards an exedy stage 2.
The upper plenum and LIM are the same on both engines.
You are better off with the 03-05 "regular" lower plenum.
James92SE
142
01-02-2024 09:23 AM
