taking apart gauge cluster to install bezel
Old Mar 25, 2006 | 10:49 PM
aih98max's Avatar
scoobystoned...
how hard is it to put a carbon fiber or alunimum gauge bezel around your gauges? could somebody tell me or post a write up or somethin. thanks.
Old Mar 26, 2006 | 08:03 AM
RA030726's Avatar
I'm nutty for Nissans
if you have a pick tool, phillips screw driver, and a 10mm wrench you can do it.
take off the lower dash under the steering columb. (2 screws)
take off the metal plate under steering columb. (2 10mm)
take off both peices of steering columb trim. (6 screws)
take off trim around gauges including cruise, dimmer and security switches (2 screws) this one is tricky so bea carefull
then you can remove the instrument cluster. (3 screws)
after that the clear cover pops off as you release the muliple tabs around it.
Old Mar 26, 2006 | 08:11 AM
99grnmaxgxe's Avatar
There is a really good how-to in the stickies with pictures and all.
JRod28
Dec 29, 2023 09:56 PM
Slamrod
Apr 10, 2016 05:24 PM
homeyclaus
Sep 3, 2015 06:15 PM
acw
Aug 13, 2015 12:50 AM
