Need motor mount advice and prices
I found out from my mechanic that I need to replace all my motor mounts, he told me it would be $650 including labor and parts. I want to know if that is worth it and if there is a cheaper way out of this. If anyone could provide me with sources on where I can get the parts for the cheapest price I would appreciate it.
All my mounts have gone bad from what the mechanic told me? Does that mean I have to replace them or I could buy one of those mount inserts and put it on? I am completely a noob with these motor mount things.
ES makes motor mounts for the maxima on Suspension.com. I just ordered mine. $80 for the fronts and back but they are inserts that push into your old mounts. They will be a bit stiffer then stock. Will result in a slightly harder idle.
-matt
-matt
Originally Posted by bigdog97max
hey matty, where are you gonna go to get those inserts put into the mounts? i've wanted to get these for a while, but i can't find anyone who will put them in for me.
-matt
Will these inserts work the same way if I replace it with a new mount besides the exception of a stiffer ride and harder idle? My engine is hoping like crazy when I step on the gas, makes me feel like I lost a lot of power. I just want to find a cheaper way to get out of this.
-matt
http://www.buynissanparts.com/
They have low prices, and you can use them as a comparison if you want to go the non OEM route...
I went on the site and checked, if I need all four mounts it would add up to $382.60 just for parts. The next thing is that I noticed is that the front mount for a GXE is different from a SE or GLE, can anyone tell me whys that because I thought they are all VQ30DE motor and the engine layout should be the same. The price for the front mount for the GXE is around 70 dollars, and for the SE or GLE front mount its 150 dollars.
Your motor is probably rocking back and forth because your front and rear motor mount are shot. Do them and see how it feels. The Trans mount and the pass side mount dont do much for the rocking back and forth of the motor.
-matt
-matt
vingodine
45
May 21, 2016 12:46 PM
Rage Maximus
Sep 3, 2015 12:26 PM
CAN-Other LF: Worn / Broken Parts
george__
Aug 18, 2015 07:06 PM
