Alternating bumper lights
Old 03-27-2006 | 10:40 AM
gen4maxima536's Avatar
any one remember how to make it so that while the turn signals are flashing, they will alternate with the site markers or have a link to the write up for it? i've tried searching but no dice.
Old 03-27-2006 | 10:48 AM
Cdg2125's Avatar
What? The side markers?
Old 03-27-2006 | 10:55 AM
86maxima96's Avatar
I Broke OT
do you mean have both of the bumper lights blinking, but alternating with eachother? never really heard/seen it done, but semms simple enough. just a little wiring work.
Old 03-27-2006 | 12:26 PM
Rick James's Avatar
http://www.geocities.com/amixam69/nissan/markerblink/
Old 03-27-2006 | 12:41 PM
aih98max's Avatar
scoobystoned...
thats awesome. im doin it tonite. thanks 4 the write up.
Old 03-27-2006 | 06:14 PM
excelent, thats what i was looking for, thanks
Old 03-27-2006 | 06:24 PM
Fast1one's Avatar
Ooo sweet...ive been wanting to do this...cool!
Old 03-27-2006 | 06:31 PM
Tatanko's Avatar
Bacon Lover
I'm curious...would this result in the side marker being off then unless the turn signals were turned on, or would it still be on constant and just blink when the turn signals were on?
Old 03-27-2006 | 06:36 PM
99grnmaxgxe's Avatar
Good question. I wonder the same.
Old 03-27-2006 | 06:38 PM
Tatanko, found our answer
" the wireing should result in alternate blinking with lights are on...
markers blinking in sync when lights are off,
and normal marker operation when not blinking"
Old 03-27-2006 | 06:52 PM
DR-Max's Avatar
That will only work with the parking lights on. It won't alternate when its not on.
Old 03-27-2006 | 06:59 PM
Okay, I'm a total n00b when it comes to electronics, when it says tap a wire from the turn signal to the sidemarker, does that mean get a new wire and connect it to the green to black wire? Also on when you cut the black wire on the sidemarker, do you leave the top half of the wire alone to hang?
Old 03-27-2006 | 07:07 PM
Cdg2125's Avatar
Tapping a wire can be just splicing off the coating and wrapping the new wire around the exsisting and then wrapping electrical tape. Thats the easiest way. You can buy a wire tap if you'd like from Radioshack. But just the same as tapping it directly. Dont leave wires haning ever. Always wrap them up with electrical tape.
Old 03-27-2006 | 07:36 PM
aih98max's Avatar
scoobystoned...
i didnt get a chance to do this today, but i will tomorrow before i leave for cali for the rest of the week.
Old 03-27-2006 | 08:37 PM
Tatanko's Avatar
Bacon Lover
Even though I almost always have my parking lots on while I'm driving, it seems to defeat the purpose here. There's got to be a way to wire them up to alternate without the parking lights on.
Even better...I'd like the side markers to blink in sync with the actual turn signals, rather than alternate.
Old 03-27-2006 | 11:32 PM
maybe use a diode and or a relay. i'm not that big into the wireing but it makes sense
Old 03-28-2006 | 08:02 PM
aih98max's Avatar
scoobystoned...
i was gonna do this tonite but its rainin
Old 03-28-2006 | 08:08 PM
ti2tmax's Avatar
Has his VINs memorized
I did this today, and it works just as advertised! when lights are not on, they blink together, when the lights are on the blink alternately. And it doesn't alter the foglight rewire mod either.
Old 03-28-2006 | 08:20 PM
Tatanko's Avatar
Bacon Lover
Interesting...
When you say it doesn't alter the fog rewire, what did you tap for signal for the fogs?
Old 03-28-2006 | 08:23 PM
ti2tmax's Avatar
I tapped into power on the pass side parking lamp for the fog light mod, and the ground is the one you cut on that lamp for the alternating blinker mod.
Old 03-28-2006 | 08:27 PM
BlackMaxdout's Avatar
you shoulda just tapped the accessory signal to the wiper relay, for your fog lights. It's been corrected so that using your wipers doesnt affect the operation of the fogs.
Old 03-28-2006 | 08:30 PM
ti2tmax's Avatar
oh, well. I did that mod last summer I think... Thanks for the updated info though!
Old 03-28-2006 | 08:59 PM
Tatanko's Avatar
Bacon Lover
I'm too tired to think...if I did this mod and cut the power wire to my side markers (so that they didn't come on with the clearance lights) would they still light up with the turn signals if I did this mod, or not? I'm debating whether or not to just pull the bulb to my sidemarkers and call it a day, since I like the cleaner look without them...but if I can put them to good use for side indicators of the turn signals, all the better. If my limited knowledge of electricity and my understanding of how this mod works serve me right, I'm guessing no.
If no, could I possibly wire this all up a different way to achieve what I want?
Old 03-29-2006 | 09:06 AM
Black Maxima
Make sure to solder all the connections and finish with electrical tape...
Old 03-29-2006 | 10:03 AM
Cdg2125's Avatar
You need to find the blinker wire (27 watt i believe) and run it to the power of the side light. So the light should light yup and blink at the same time. Kinda like the bumper rewire mod from VQ. Seems like its backwards on this. Just try wiring it. If it's wrong you'll blow a fuse. Just replace it. It should be fairly that easy tho.
Old 03-29-2006 | 11:01 AM
sunten1
This was a sweet mod....
tsi6001
10-03-2022 11:23 PM
JMag90
08-25-2015 10:17 AM
doobadoo
08-15-2015 07:43 PM
Samedi
08-13-2015 05:05 PM
Quick Reply: Alternating bumper lights
