clanking noise please help
Old Mar 31, 2006 | 01:40 PM
19maxima97's Avatar
hi, when i turn my car fully with my steeringwheel, meaning it wont turn anymore, and back out of my drive way, it makes some kind of clank noise or something. im heard something like this is a strut bearing. any opinions?
Old Mar 31, 2006 | 08:26 PM
MDeezy's Avatar
at full lock you can hear the power steering pump whine a little bit.
Do you hear this noise every time you reverse at full lock? Two parts could be colliding.
Old Apr 1, 2006 | 09:26 AM
clive's Avatar
100% chingon
A 'clunk clunk clunk' sound when you are turning at full lock, is quite possibly the CV joint failing. Jack the car up and put it on stands so you can turn the front wheels freely from side to side. Have someone do that for you while you check that the tyres are not fouling anything under there. If there's nothing getting in contact with the rotating surfaces, check the rubber boots (covers) where the axle enters the hub. Are the boots secured properly, with a plastic band holding the covers on? Are the rubber covers intact? You'll quite probably find something amiss by the sound of it.
Old Apr 1, 2006 | 09:40 AM
MDeezy's Avatar
could be ball joint also
Old Apr 1, 2006 | 04:06 PM
DennisMik's Avatar
it could be his strut bearings or he just might need to grease his turns stops.
Old Apr 1, 2006 | 06:34 PM
19maxima97's Avatar
i dont think it would be the CV joint, i'm pretty sure its not a ball joint, it hink it could be the strut bearing but how can i make sure?
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
