Quick ??- 99 Maxima ECU
I found out my computer is no good. I have a 99 Maxima SE(5-speed) and was wondering if a computer from an 99 maxima automatic would be ok as a replacement. If not what years are compatible for the 99 Maxima Ecu? Thanks for all the info guys and sorry for posting here but could not find a sticky that had the info I needed.
If you've got the immobilizer, you would have to have the ECU and key re-programmed to match eachother, I believe.
Or maybe I'm thinking of my research on the 3.5 ECU. Anyone know if the immobilizer uses the ECU to recognize the key in the '99?
Originally Posted by motocross416
you would have a check engine light with a couple of automatic transmission codes
if you don't mind the check engine light it would be fine, but you will fail emissions testing if you have them in TX. I would check car-part.com and call around to some local junk yards to see if anyone has them, watch out though. prices can vary widely on used ecus
hey do you know if one from a 2001 maxima SE 5-speed would be ok to use???
I dont think it would work, the CPS sensor I believe reads different than our 4thgens, among other sensors. You'd have codes all over the place.
Not to mention the ecu would want to open up a VI that isnt there.
JR25,
Curious. How did you determine that your ecu was not working and what were the symptoms you were experiencing to make you think something might be wrong?
My check engine light came on recently. Unexpectedly, I did not get any blinking lights from the ECU unit telling me what code had been thrown. Made me think something might be wrong with my ECU box -- though do not know how one goes about know that the ECU is a problem.
There was a TSB for ecu's but that was for the 95/96s, and it didnt happen oftern.
Explain the problems you guys are having, I have a feeling its not the ecu that is the problem. I had an issue with my car, that I though might have been the ecu (timing was off and all sensors were spot on in spec), but after more tinkering car, started and it wasnt the ecu at all.
Exhaust all options before you replace your ecu.
Also if you know its your ecu. go to www.car-part.com search for an ecu over the USA, find a good one for a good price,call the junk yard and see if they ship.
Originally Posted by 99pearlGXE
JR25,
Does anyone know if a 97/98 Se 5-speed computer would work without throwing a code????
Did you check the spark plugs also?
Did you use a coilpack from a good cyclinder and test it on the bad cyclinder?
is your car cali spec or fed spec?
match fed spec ecu with your fed spec car, or vice versa.
Oh and the spark plugs are good as well...
there are two types of maximas, cali spec and fed spec. basically cali spec has more emissions equipment than fed. I believe its in the stickies on how to tell the difference
Finkle
Sep 27, 2015 09:53 PM
