1995 B-pipe to 98?
Old Apr 3, 2006 | 03:18 PM
tavarish's Avatar
fwd gone rwd cr00
1995 B-pipe to 98?
Hey, I'm going to replace my b pipe on my 98 GLE, because it's rusted and bent. Can i swap in the one from my 95 parts car? It's brand new. I know the 95-96 and 97-98 exhausts are a bit different. Can anyone shed some light on this?
Thanks,
-Freddy
Old Apr 3, 2006 | 10:40 PM
tavarish's Avatar
fwd gone rwd cr00
nobody?.............
Old Apr 3, 2006 | 11:40 PM
Scooobay's Avatar
try it and see what happens ftw O_o....
Old Apr 4, 2006 | 06:40 AM
tavarish's Avatar
fwd gone rwd cr00
i'm trying to avoid doing any extra work, especially exhaust work.
Old Apr 4, 2006 | 08:54 AM
tavarish's Avatar
fwd gone rwd cr00
bump..........................
Old Apr 4, 2006 | 09:14 AM
Tim96I30t's Avatar
I was going to do this for a local member with my 96 b pipe on his 98 max. The easiest way to do it if your front flange near the O2 sensor is ok to use from your pipe. If you cut it after the 02 sensor and weld or clamp the 96 bpipe on after the 02 sensor. You will have your 98 front with the o2 sensor and a couple inches after to clamp or weld your 96 to it. This way you can leave the 02 sensor installed cut after it and either clamp or weld you new one on and cut it where you need to so it fits. Hope this helps...should be the easiest way to do it as well.
Old Apr 4, 2006 | 09:45 AM
tavarish's Avatar
fwd gone rwd cr00
so i'm guessing it isnt a direct bolt on?
Old Apr 4, 2006 | 10:13 AM
motocross416's Avatar
it should fit, but it might sit in a bit from the bumper. I think the extra length on the 95-96s is from the axle back section so it should fit fine, if not, it will just sit about 2 inches closer to the car. you'll need a bolt to plug the o2 bung on the b pipe
Old Apr 5, 2006 | 09:16 AM
Tim96I30t's Avatar
Might be the same length I am not sure, but the 95-96 don't have the O2 bung. So if they are the same size you need an O2 sensor bung, drill and weld. It is easiest to just cut you b pipe a few inches after the 02 and then clamp or weld the rest od the new b-pipe on. It is only one clamp or one weld spot and it will be the cheapest way. There is no removal of the 02 sensor is needed just support with something then connect new one. Looking at the factory b-pipe after the resonator the pipe is crushed from the factory, I would cut it and put in a round piece there for better flow. I mean the spot it is crushed after the resonator is like 1" oval and it would be easy to make it 2.25 coming out of the resonator before the bend with no crushed spots.
Old Apr 5, 2006 | 09:52 AM
Nealoc187's Avatar
SLOW
95-96 B pipes are about 6" longer than 97-99 B pipes. 97-99 cars have an "S"pipe as they call it between the B pipe and the cat, which 95-96 cars don't have. This S pipe is where the O2 sensor is on 97-99, whereas on 95-96 the O2 sensor is actually in the cat.
You could make it work but it won't be a direct bolt on. If you remove the Spipe I think it would bolt right up, but then you have to figure out what to do with your O2 sensor which now no longer has a bung to go into...
Just get under both cars and look at where the bpipe and cat comes together and you will see what I mean.
halfpol
Oct 17, 2022 12:16 PM
Maxie40
Sep 14, 2015 11:28 AM
stromm
Aug 27, 2015 04:13 PM
Team STILLEN
Aug 10, 2015 04:29 PM
