OIL leak (i think)...HELP!
Old Apr 10, 2006 | 06:40 PM
motorheadwannab's Avatar
OIL leak (i think)...HELP! PICs
There is oil (or at least I think its oil) coming out of the front bank header. It is only on the lower of the 2 bolts but it is definitely there. I have never touched my headers and am trying to figure out what is going on. If you look in the first picture you can see the header bolt next another bolt. This is the outlet on the end closest to the timing cover. What is that bolt next to the header bolt and what does it do? It looks like there is a major leak coming from there. Again I have never touched this part of my car before so I am really in the dark. HELP ME! And no don't say screw that engine, get a new cheap used one with low miles...its not doable right now. Thanks
Old Apr 10, 2006 | 08:01 PM
JNCoRacer's Avatar
Just the tip.
Could you maybe take another pic further away.
Old Apr 10, 2006 | 08:31 PM
matty's Avatar
Yea please take a picture from a bit farther out. I cant tell but from those pics it looks like its the valve cover gasket to me.
-matt
Old Apr 10, 2006 | 08:56 PM
Old Apr 10, 2006 | 09:10 PM
matty's Avatar
I can see that it looks like your timeing chain cover was taken off and resealed ?? Am I correct with that red line of silicone on the timing chain cover ??
Probably wanst sealed as well as it should be. Without that line to guess from, I would say the valve cover gasket but it wouldnt leak from JUST that one part if it were the gasket.
Could be the valve cover gasket though
-matt
Old Apr 10, 2006 | 09:13 PM
yes it was resealed but it was done poorly and I think it needs to be re-done
Old Apr 10, 2006 | 09:15 PM
matty's Avatar
You answered your own question. If theres alot of miles on the motor, maybe you should replace with a low mileage motor I know you dont wanna do that.
-matt
Old Apr 10, 2006 | 09:20 PM
Ya but i don't see how a small leak at the bottom of the timing cover can cause oil to be on the header bolts...And just a little side note, I have been looking over the timing cover and i think it could be a simple procedure, there isn't really much connected to the cover itself, all the time and labor comes from taking off the plenum and oil pans...which it appears isn't required unless the chains will be replaced. And no low mileage motor swap...
Old Apr 11, 2006 | 03:41 AM
njmaxseltd's Avatar
That actually looks like it could be coming from a leaky front valve cover gasket.
A very easy and cheap fix.
Old Apr 11, 2006 | 05:18 AM
JNCoRacer's Avatar
Just the tip.
Yeah thats what I was just thinking.
Old Apr 11, 2006 | 06:00 AM
KaZ's Avatar
KaZ
How sloppy are you with filling your own oil? Are you a neat freak about it, or do you just pour it in and clean up the mess after the fact? I'm a bit of a neat freak, but I tend to just pour in without a funnel (albeint being careful) then cleaning up any "extra" with a rag... but I just changed my spark plugs the other weekend and took that cover off for the first time... Its sorta sealed to help prevent oil from getting under/etc, but some still seaps by and can eventually get down to the areas you're showing having oil... just a thought. But like everyone else said, its more than likely a valve cover or the front timing chain cover seal
Old Apr 11, 2006 | 09:25 AM
lol ya sloppiness could be an issue but highly unlikely, but anyways you guys think is a valve cover gasket...Huh, I probably wouldn't have guessed that, is it fairly simple to replace?
Old Apr 11, 2006 | 09:37 AM
Tim96I30t's Avatar
That looks like a mess, the amount of work needed to replace gaskets is not really worth it when you can get a low mileage 3.0 for $400-$500 avg. I know you don't want a new engine but sometimes it isn't worth spending the time and money required to fix the old one.
Old Apr 11, 2006 | 10:24 AM
JNCoRacer's Avatar
Just the tip.
Not everyone here has the cash to throw around getting used motors. The majority of members arent afraid to do a little work and get dirty.
I dont remember how musch the valve cover gasket was but I know its very easy to change. You can use a bit of RTV silicone to hold the gasket in place when you put it back on. While you're at it, check the seals for the spark plug chambers, they will be on the underside of the valve cover. When you put it back together make sure you torque the bolts down to specs...make sure not to over-tighten.
I hope everyone's info will lead you in the right direction. Dont give up or get frustrated with those trying to help on the .org, it's kind of hard to diagnose a problem without actually looking at it in person.
Old Apr 11, 2006 | 06:40 PM
Ya, no go on the new used motor, but I was looking online at checker's website and you can get a valve cover set for around $60 or just a single valve cover for $10. What do I need? And thanks again guys, idk what I'd do without the .org
Old Apr 11, 2006 | 06:43 PM
matty's Avatar
Get the Valve Cover set. It will come with the Valve Cover Gasket, the Three Sparks Plug Guide Tube seals, and the Grommets youll need at every bolt. Just go to any local auto parts store and purchase there. FELCO should be the brand
-matt
Old Apr 11, 2006 | 08:38 PM
Do you mean felpro...
Old Apr 11, 2006 | 09:12 PM
matty's Avatar
yea sorry..lol
-matt
Old Apr 12, 2006 | 09:44 AM
Alright well I was just looking at the valve cover set and I replaced that seriously like a month ago, did I put it in wrong or what??? I torqued to spec but i didn't use any rtv...could that be the problem? I replaced the sparkplug guides and bolt grommets and everything...
Old Apr 12, 2006 | 10:08 AM
matty's Avatar
You probably didnt replace the 10 Grommets around the valve cover at each bolt. Those are important. Looks to me like they're originals on your motor.
You dont need RTV. I didnt use it. Thats only to keep the gasket in as you lay it back onto the motor. not important for sealing purposes
-matt
Old Apr 12, 2006 | 05:49 PM
goldmax's Avatar
Have the same leak problem with the back valve cover gasket. Looks tough to change out...anyone done it?
Old Apr 12, 2006 | 09:52 PM
Ignore the re-use of this photo, but is do you mean the things I have highlighted red? because yes I did replace all of those, front and rears.
Old Apr 13, 2006 | 11:49 PM
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
