Really Quick Help
Old Apr 11, 2006 | 09:11 PM
cleanmax's Avatar
Really Quick Help
Just Changes Slave Cyclnder And Now Clutch Flops To Ground, What To Do
Old Apr 11, 2006 | 09:15 PM
tcrow31's Avatar
you can use your hand and pump it up and down a few time and it should build some pressure than you can bleed it
Old Apr 11, 2006 | 10:00 PM
Mr.Duck's Avatar
make sure there is no air in the system, bleed it correctly
Old Apr 13, 2006 | 04:23 AM
cleanmax's Avatar
i got it i found a great way to get the air out the line. Get a little oil pump, the one that has a lttle can on the bottom and you squirt it out with the hand pump, well take that and fill it with brake fluid, get a piece of vaccum hose and put one end on the can and the other end onto the bleeder screw of the slave (the bleeder screw has to be loose) and then just pump a couple of times and your done .
Mar 12, 2020 12:06 AM
NewMax03
Oct 7, 2015 08:27 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
