Changing Fuel Filter
Old Apr 14, 2006 | 04:36 PM
radicht's Avatar
I am trying to change the fuel filter on my 97 max, but am having a hell of a time pulling the hoses off (I believe that it is the original oil filter). I started the car, and then removed the fuse for the fuel pump. Then I tried to start the car about 5 times (5 seconds each). I removed the top and bottom clamps. However, when I try to pull the top hose off, it will not budge. Is there a trick or some kind of solution I can use that will loosen the hose for me?
Old Apr 14, 2006 | 04:52 PM
plate's Avatar
No trick. Just lots of patience. Keep gently squeezing and
pulling the fuel hose, it will come out.
Even with depressurization there will be a good
amount of fuel in the filter so be prepared when
you take the bottom hose off.
You're gonna love putting them back on.
Old Apr 14, 2006 | 04:56 PM
whitemax21's Avatar
I have read that some people actually break the neck off of the filter, since you won't be using it anyway. Then, you can take some needle nose pliers and remove the broken piece from the hose. Or, if you have enough extra hose, you could cut as close as possible to the old filter.
Old Apr 14, 2006 | 05:10 PM
98maximagle's Avatar
I used a short flat screwdriver to pry the hose off the old filter
Old Apr 14, 2006 | 05:20 PM
Maxima880's Avatar
Like everything on the Max it's hell to get to. Took me twenty minutes to change my PVC valve today. That's my single complaint about this car - everything is blocked or covered by something else.
Old Apr 14, 2006 | 05:40 PM
maxima775t's Avatar
When I had to get the brake booster line off to use Seafoam, I used a pair of needlenose pliers to grip the end of the hose and slowly but firmly move it back and forth, kind of scootching it off. It's slow, but works nicely and does no damage.
Old Apr 14, 2006 | 08:06 PM
sky jumper
Originally Posted by Maxima880
Like everything on the Max it's hell to get to. That's my single complaint about this car - everything is blocked or covered by something else.
man you need to try working on a GM or Ford product. we 4th genners are lucky. how many transverse mounted V6s out there give you free access to the rear bank spark plugs?? every time I work on this car I marvel at how well the engine bay was planned out. of course I have not had to change the KS yet...
Old Apr 14, 2006 | 08:12 PM
Pieps's Avatar
just wait for that KS, hope you have some small hands
Old Apr 15, 2006 | 05:16 AM
Maxima880's Avatar
Yea your right, I've got to admit that while quarters are usually tight the engineering is such that the job can be done. I remember certain cars in the 70s that it was impossible to access one spark plug. You either had to torch a hole through a fender well or lift the motor out to get at it. The Max is the best engineered vehicle i've owned and that number is around 20 now. By the way, I've done the knock sensor - it wasn't so bad.
Old Apr 15, 2006 | 05:55 AM
speed racer's Avatar
Use a needle nose plier and start twisting the fuel filter while the hose is clamped. This will release some pressure and will make it easier to pull off. Just be patient and keep pulling while twisting.
Old Apr 15, 2006 | 04:24 PM
ThurzNite's Avatar
werd on speed racer. Needle nose clamped onto the rubber with right hand, left hand holdin filter, and torque back and forth to break it free, then loosen the plier grip and pull while twisting. Takes a few min. To get the bottom, hold the hose w/left hand, right hand holds filter and twist. Same concept.
Or, after getting the top hose off, drop the filter down below and work from under. I've done both ways, and prefer doing it from above. 10min job, go to it. Good luck, and don't inhale the gas. Be sure to clean any spilled gas.
Jae
Old Apr 15, 2006 | 04:34 PM
Kolyan's Avatar
i had hard time too and thought that it was impossible.......my roomate pulled it so hard that it came off the same second
Old Apr 15, 2006 | 05:41 PM
Pieps's Avatar
just make sure that you depressurize the system as much as you can. I changed mine and i had gas leak all over the place. Just have a rag handy like the sticky says, it will come into play.
Old Apr 19, 2006 | 01:49 AM
flynlr's Avatar
I have big hands when i did mine blood everywhere but after done cuts healed and all was well
Old Apr 19, 2006 | 02:10 AM
Turbo1er's Avatar
Doin' it 4 da shorteez
WTF? Just get the Ebay fuel chip!
Old Apr 19, 2006 | 03:02 AM
nhaven's Avatar
I applied a little bit of WD40 to the "neck" of the filter when there was a little bit of separation between the neck and the hose. It made the job of twisting and pulling and pushing a lot easier.
Old Apr 19, 2006 | 03:16 AM
1996blackmax's Avatar
I am not looking forward to doing this again.
Old Apr 19, 2006 | 05:40 AM
Juicey's Avatar
This ORG has saved me $$$$$$$$
I'm not looking forward to doing it at all by the sounds of things.
I've owned GM cars and my last GM I actually had to turn the wheels and go in under the right wheel well to get to the oil filter. Maxima's are 100 times easy to fix and work on.
Old Apr 19, 2006 | 09:32 AM
Wait till you water pump goes out, and you contemplate doing it yourself .
Old Apr 19, 2006 | 10:37 AM
toddemullins's Avatar
Speaking of fuel filters, does anyone know the part number for the 300ZX fuel filter that guys are putting on thier 4th gen Maximas? I'm planning on replacing mine very soon and need to buy one. Or is it a waste to use the 300 filter? I'd do a search and find a thread, but I'm a noob to the forum.
Old Apr 19, 2006 | 11:05 AM
maximus_96's Avatar
i used a z filter. i just bought it for a 96 year Z for no real reason. it fits the hoses and the bracket. i had to change mine last friday and it was a pain to get the damn hoses off. putting them back on was piece of cake. remember, twist and pull, pulling straight out will only make it tighter.
put a bag under the filter as you remove the bottom hose. it'll catch most of the gas.
Old Apr 19, 2006 | 05:28 PM
Bobo's Avatar
Take your gas cap off as well.
Old Apr 19, 2006 | 05:30 PM
FL600's Avatar
I just replaced mine and it was tough as well. Try twisting it while holding the hose so that you don't twist the hose. I kept doing this and it came right out. I did cut the hell out of my arm on all of the stuff under the hood. Good Luck
JoshG
51
Sep 21, 2015 10:41 PM
iamute
Sep 20, 2015 05:22 PM
bumpypickle
Sep 20, 2015 08:22 AM
aminus21
Sep 12, 2015 04:53 PM
sdotcarter
Sep 2, 2015 09:53 PM
