radio ? please help
Old Apr 16, 2006 | 06:29 PM
madmax96's Avatar
radio ? please help
ok guys this is what happen.i have a 96 maxima and it has the bose head unit with the cd/tape/and cd changer built in. it has been going out and in so i got a new radio and put it in but its still not working.at least theres no sound coming out of the speakers.the radio is working except for that.if you have had this happen to you please let me know what to do to fix it.
thanks jason
Old Apr 16, 2006 | 06:47 PM
madmax96's Avatar
never mine i believe i know what i have to do now.i got to get another part to make it work.another 60 bucks.
Old Apr 16, 2006 | 07:08 PM
Sounbwoy's Avatar
sigh...how often do we see this? First, do you have the Bose speakers? Unless you have the Schose (sp?) adaptor it won't sound good as the Bose speakers work off two (or is it one ohm, plus a slightly different level signal).
Second, and this is probably what happened to you, is to make sure that the remote amp turn one wire is connected. Each speaker has it's own amp. If the remote amp turn on wire on the HU is not connected, you won't have any sound. So recheck your wiring, and get that adaptor if you don't already have it. You can get them on ebay or Crutchfield.
Old Apr 16, 2006 | 09:56 PM
z0dE's Avatar
You had it right, Bose speakers are 2 Ohm and self amped. If you are using the Bose speakers make sure you have the 6 wires per speaker hooked up in the back of the head unit. They have power, signal, ground and remote wire to the individual amp and then 2 more going to the speaker for the high/low pass filters on each speaker. By the way, to much dismay Bose are not that good of speakers. There is a saying we have in the Labs at school. "No Highs, No Lows, Buy Bose."
Old Apr 17, 2006 | 06:38 AM
1996blackmax's Avatar
I've heard it as "no highs, no lows, must be Bose" .
Old Apr 17, 2006 | 08:20 AM
runyun972's Avatar
Originally Posted by Sounbwoy
Unless you have the Schose (sp?) adaptor .
Scosche
and at crutchfield - they sell for $49.00
Old Apr 17, 2006 | 08:22 AM
runyun972's Avatar
btw - here's the link for the adapter
http://www.crutchfield.com/S-sEKpjMq...nissan+adapter
Old Apr 17, 2006 | 08:39 AM
Sounbwoy's Avatar
Don't forget tho, listening tastes are individual. I like how my Boses sound. I do have an aftermarket head unit and it made them sound better than with teh factory unit. I don't listen to music with a lot of emphasis. I prefer slightly positve of flat, and I get good definition and clarity.
But if you like a lot emphasis, then yes there are better choices.
Old Apr 17, 2006 | 09:30 AM
madmax96's Avatar
i just want some tunes im not looking for a great sounding system in it.i have my s10 for that.but this is just my beater car.as long as it sounds like the factory **** im fine with that.
thanks for the info and the link.
Old Apr 17, 2006 | 11:26 AM
In my car I use the parametric EQ to cut peaks in my system, this way I can try to get a flatter frequency response. When I measure the frequency response in my car it is not flat, this is with all of my settings to zero. I have a couple of problem areas in there (peaks). Pretty hard to get good definition and clarity with a stock sound system, as you cannot adjust for these abnormalities which can cause music to sound boomy or harsh at times. This along with actory speakers in our cars makes it even harder. Factory speakersjust cannot compare to a good set of aftermarket components. If you like stock that's fine, but some people with aftemarket systems go this route to get good definition and clarity . We do not do it for emphasis on certain frequencies, just emphasis on good sounding music is all .
gavin68
Sep 18, 2021 12:36 PM
chisam14
Nov 6, 2018 08:56 PM
mikeg75
Nov 30, 2015 05:12 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
