Checked my car today...wish i hadn't!!!
Old Apr 18, 2006 | 06:04 PM
99se5speed's Avatar
SHIFT_up
I went to the mechanic and he lifted my car up for the first time since i bought it...what a mistake that was.
My rear engine seal is leaking...it seems pretty bad to me but i'm not really loosing the much oil, it's still the same level it was a month ago. The mechanic quoted my 350 to replace the rear engine seal....OMFG!!! for a 30 piece!!!
When he was lifting it, when it was barely off the ground i already noticed my front strut boots are all so are my bushings and my rear left boot.
Basically i wanted to know if i should just replace all 3 boots or just replace all 4 struts. The mechanic said 50 dollard per strut no matter if it's just the boot or the whole thing. And 30 for each bushing to replace. Are these good prices? should i get stock SE stuff or what would u guys recommend.
I Also asked him to check my axles...he said there tip-top so i'm gonna be putting in the new amsoil oil and my ss clutch line tomorrow.
Old Apr 18, 2006 | 06:08 PM
MaxGordon7's Avatar
wow those are good prices.
Old Apr 18, 2006 | 06:09 PM
99se5speed's Avatar
SHIFT_up
really? cause when he told me how much to fix the seal i started to laugh and i was like stop F***in with me. LoL
But what should i do about the suspension?
Old Apr 18, 2006 | 06:37 PM
mforrest100's Avatar
For the suspension that is good price. The first time I went to get a quote on my suspension, I was told $150 a corner. On another note, go into your local forum and put a post "willing to pay someone to changes struts" thread. A lot of people do this and you could probably save some money. And this is a good time to get a drop if you don't have one.
Old Apr 18, 2006 | 06:51 PM
99grnmaxgxe's Avatar
LMAO @ the title, yeah but the suspension quotes you got are good. Labor at a service shop is like $70+ a corner.
Old Apr 18, 2006 | 07:02 PM
99se5speed's Avatar
SHIFT_up
so what should i get? should i just change the boot or struts or spring i don't even know what i should change...someone point me into a good direction plz as to what i should change and what i should get...Thanks alot all for the imput sofar.
Old Apr 18, 2006 | 07:03 PM
aih98max's Avatar
scoobystoned...
ya those are good, i would for sure just go ahead and buy a full suspension kit right now with a drop. good time to do it. i am doing it soon.
Old Apr 18, 2006 | 07:09 PM
FishyMan's Avatar
do u guys need or do we need chamber kits or stuff like that??
my boots are hashed but teh struts are fine. its no biggie to me if car was dropped if it'll provide more probs, but i would try change to an afterkmarket OE strut like tokiko and some other. im not sure which one it is.
Old Apr 18, 2006 | 07:13 PM
99se5speed's Avatar
SHIFT_up
mine struts and everything is fine...it's just the sand boot that's ripped on 3 sides. I can't stand the fact that it's ripped. What do i need to lower the car...i don't have 800 or so to drop on a new suspension, but what would i need to just lower the car without full suspension.
P.S. If you haven't already noticed I AM A COMPLETE UBER NOOB.
Old Apr 18, 2006 | 07:20 PM
HM_Motorsports's Avatar
The reason the labor is so much is to change the boots they have to completely take out the struts and disassemble the strut assembly to get a new boot in there. The price of labor probably wouldn't go up much, if at all, if you changed springs while they did it, they have to take them off anyways. That's all you'd need to lower your car is a new spring set and camber bolts to correct the alignment. Spring sets can vary but you should be able to get a decent set for around $200.
Old Apr 19, 2006 | 12:35 AM
99se5speed's Avatar
SHIFT_up
bump...what should i change in my suspension to make it lower and fix my boot? looking to spend say 300-400
Old Apr 19, 2006 | 12:38 AM
D-Bo's Avatar
Droppin logs
Why wouldn't you want to know what's going on with your car. Ignorance isn't bliss...
Old Apr 19, 2006 | 12:57 AM
99se5speed's Avatar
SHIFT_up
I didn't mean i didn't wanna know what's going on, all i meant was that i coulda lived without finding out that i have all these problems.
Anyway i did some quick research and i think i should get the AGX shocks and struts. Any comments on that? Hows the ride comfort? and handling on them?
Old Apr 19, 2006 | 02:17 AM
MaxedOut99SE's Avatar
Dude where at in NY is this? I need a hook up on getting my suspension changed
Old Apr 19, 2006 | 02:46 PM
99se5speed's Avatar
SHIFT_up
It's in brooklyn...umm around the ocean parkway area. But you'll prolly have to come with me to get those prices.
Anyway PEOPLE HELP!!! What should i change?
Do i need to change the strut? or the springs? or the coil?
Old Apr 19, 2006 | 03:47 PM
black97's Avatar
Go to NISSAN stealership get a quote on the same work especially on rear oil seal be like go back to your mechanic, get the job done and be happy.
Old Apr 19, 2006 | 03:51 PM
99se5speed's Avatar
SHIFT_up
i'm getting the job done regardless but i don't know what i should do with the suspension??? What should i change to lower my car since only my boot it torn.
Old Apr 19, 2006 | 04:08 PM
DJ420's Avatar
Bad Mother Fornicator
Yeah thats no BS! After you go to the stealership, you may want to KISS your mechanic!! Those suspension labor prices he gave you are very good! (I know, I work at the stealer! ) If yer in there anyways, I'd always recommend doing the struts too! HOWEVER, if you are on a budget and dont want to spend the money and your struts feel fine.. just buy 4 new boots (I recommend OEM on these, though..), a set of 1.5" lowering springs ($100-200/set - look around, and dont forget eBay can be your friend! LoL).. then bring them to your mechanic, and have him call you when its done!
DJ
Old Apr 19, 2006 | 04:26 PM
badcooliebwoy's Avatar
Listen...if you want to lower your car, you have to change BOTH your springs and your struts. Yeah the springs will lower your car but the OEM struts can't take that pressure and they will blow out on you quickly once your car is lower. If your gonna do it.....do it RIGHT! Change both your springs and struts, it will save you time and $ in the long run. I personally would recommend H&R springs which are like $250 and Tokico Illumina Shocks which were $300. Thats what I have and they are a nice ride. Of course they are rougher than OEM springs and shocks...but i'll live. If your not willing to spend the $ to get your suspension done correctly then leave it stock. Fix the leak now n save up for the suspension kit later.
Old Apr 19, 2006 | 04:31 PM
MDeezy's Avatar
its actually good you found this out now, rather than on the side of the road one day.
Old Apr 19, 2006 | 04:48 PM
jac121479's Avatar
my rear main seal leaks like a quart a month. the price he quoted you is good, but personally i'd do it myself, gotta drop the trans though which kind sucks...
Old Apr 19, 2006 | 05:41 PM
FL600's Avatar
Be glad you found out sooner than later....it'll save money in the long run
Old Apr 20, 2006 | 12:07 AM
99se5speed's Avatar
SHIFT_up
hey guys what do you think about um... S-Tech Springs w/ KYB GR2?
Since the GR2's aren't adjustable i can get the s-tech which go 2.2in front and 1.8in rear...i can actually afford this! How's the ride on these and is the stance good and the handling? Thanks
Old Apr 20, 2006 | 12:30 AM
MrDicks95SE's Avatar
Offset Is Everything.
negative on the GR2 and S-tech combo. youll blow out the shocks in no time. the KYB GR2's and Tokico Blues are meant for an OEM replacement, meaning no extreme drops like the 2.2" S-tech. more like 1"-1.5" drops at the most. save your money and go with either the KYB AGXs or Tokico Illuminas. adjustable more durable shocks. youll be so much happier with better shocks. as for the springs, its a very aggressive stance as the car is much lower. but to me it feels the springs are a little soft for how low they are. if you want looks but arent worried about handling, these are your springs. but if you are more into handling and not much looks, eibachs, progress will do the trick. its a less of a drop but the springs are much stiffer. better yet save your money and get coilovers. TEIN Basics and the KSport are the more popular ones due to affordability and ride. the good thing about coilovers is that the spring and shock are matched so they work as one. plus when you lower your car a good amount you wont loose as much travel as you would with a regular shock.
Old Apr 20, 2006 | 01:49 AM
99se5speed's Avatar
SHIFT_up
i want a new suspension very quickly since the summer is coming. I don't want coilovers but the illuminas and the konis are pretty expensive. I'm now looking at the Tein H-tech's and the GR2's because they pretty much fall under the price range, don't forget i'm gonna have to lay out another 300 for the install so the H-techs and the GR2 is gonna run me 450.
Old Apr 20, 2006 | 06:03 AM
ChasMan's Avatar
Rear Main seal at Nissan quoted to me a couple of weeks ago was 860.00 plus tax. 350 is a good deal.
Old Apr 20, 2006 | 06:33 AM
MDeezy's Avatar
$300 for the install? Please have an experience org member do it for much less than that. The install is ratrher straight forward, and the most difficult task is stubborn bolts. Short of that an hour or two should have the new suspension on.
Old Apr 20, 2006 | 08:31 AM
my97maxi's Avatar
wow that sucks, how much did you end up spending just to repair it??
Old Apr 20, 2006 | 08:32 AM
my97maxi's Avatar
personally i would go with the agx.
Old Apr 20, 2006 | 09:09 AM
Blackwind's Avatar
h&r and kyb gr2's
Lakersallday24
Jun 16, 2019 01:35 AM
JMag90
Aug 25, 2015 09:17 AM
acw
Aug 13, 2015 12:50 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
