Purge Valve
Old 04-21-2006 | 06:35 PM
ukmastermind's Avatar
Purge Valve
hey guys whats the difference b/w a :
Purge Control Valve
Purge Cut Valve
Not sure which i need. I get a trouble code of P0443/0807
Thanks!
Old 04-21-2006 | 09:58 PM
DJ420's Avatar
Bad Mother Fornicator
the purge control solenoid valve actually engages and disengages the purge cut valve. that error code pops up when either one go bad.. it is USUALLY the control solenoid valve that goes.. it is on a bracket near the front valve cover, closer to the battery.. there appears to be 2 almost identical on that bracket. one is for the egr, the other (usually closest to the engine) is the evap purge one.. vac lines and electrical connector to it.. put power to the switch, if it doesnt click, then its bad.
DJ
Purge Control Valve
Purge Cut Valve
Thanks!
Old 04-22-2006 | 11:14 AM
valve?
does this apply to all maximas?
i have a 95, and i know the later ones (e.g. 99) have more smog equip?
TKHanson
11-24-2018 01:39 AM
tseng1023
10-15-2015 08:30 AM
hayne
10-05-2015 11:53 AM
homeofbacon
09-23-2015 07:17 PM
tardrex
09-11-2015 07:35 PM
Quick Reply: Purge Valve
