Ball Bearing Replacement help
Old Apr 23, 2006 | 04:06 PM
Jimothy12's Avatar
My rear ball bearings need to be replaced. Does anyone have any advice?
Old Apr 23, 2006 | 04:10 PM
njmaxseltd's Avatar
DIY, purchase a new rear hub assembly.
Old Apr 23, 2006 | 04:35 PM
Jimothy12's Avatar
Why is that?
Old Apr 23, 2006 | 05:26 PM
BlackMaxdout's Avatar
Originally Posted by Jimothy12
Why is that?
because the rear hubs are generally easier to replace than the fronts. You can DIY quite easily. Just go out and buy the assembly, and start wrenching.
Old Apr 25, 2006 | 05:24 AM
Jimothy12's Avatar
What size are the rear bearings?
Old Apr 25, 2006 | 08:58 AM
azn_s3nsation87's Avatar
You replacing yur bearings is it because it's making annoying sound? Because some people including me having continuously clicking noise when they cruise slowly. They think one is the axels or 2nd is the wheel bearings. I'm just wondering is that yur problems, so i'll know exactly what it is so I can fix mine. Thanks
Old Apr 25, 2006 | 09:03 AM
Jimothy12's Avatar
only recently when drive slow or fast there is a constant ticking sound on every rotation. I was told by a few people that it is probably my bearings. Is that incorrect? I dont think I am going to replace my hub unless I have too.
Old Apr 25, 2006 | 09:19 AM
Same here, i dun think you need to replace it, just try to fix it see if it goes away, if not i guess have to replace it. Let me kno the result.
Old Apr 25, 2006 | 09:31 AM
Jimothy12's Avatar
What else would be wrong and how would I fix it?
Old Apr 25, 2006 | 02:38 PM
SMX95's Avatar
So you mean to tell me if the bearing race has groves, and the bearings itself has a blue tone just slap on more wheel bearing grease and call it a day huh?
Old Apr 25, 2006 | 07:42 PM
i reallly dont kno anything about fixing or replace wheels bearing, it never happent to me before. So i got no clue, but what i heard about solving this problems are either axles or wheels bearing.
Old Apr 25, 2006 | 08:46 PM
MDeezy's Avatar
for the rear you have to replace the whole hub.
Old Apr 26, 2006 | 05:04 AM
Jimothy12's Avatar
I have to replace the whole hub? I can't just replace the bearings?
Old Apr 26, 2006 | 06:08 AM
ChasMan's Avatar
You can replace just the bearings. Check out Motivate.ca
It looks like a lot of work though.
Old Apr 26, 2006 | 06:14 AM
Jimothy12's Avatar
Motivate.ca?????
Old Apr 26, 2006 | 06:22 AM
95mtlMAXSE's Avatar
shift_Puff
it is a lot of work(front)...and don't leave any ofthe old bearing parts on the car...change it all. It makes a world of a difference...for the rear...the bearings come with the hub...less expensive if u get the non abs one...even if u have abs it'll fit, but no more abs(if u don't mind that) or get the one withthe abs sensor for like $100 more.
Motorvate.ca is the best website for maximas. It's now underconstruction, but most of the links work...enjoy wrenching
Old Apr 26, 2006 | 06:30 AM
MDeezy's Avatar
http://www.motorvate.ca/mvp.php
And the write up is for the front wheel bearing. Rear you have to replace the whole assembly. Check the FSM/Haynes.
Old Apr 26, 2006 | 08:00 AM
Jimothy12's Avatar
I spoke with my loacl dealership and apparently Nissan doesn't make the rear Hub Assembly for a 96 with ABS anymore. I will need to purchase 2 new rear hub assemblies, 2 dust caps, and 2 speed sensors. Roughly $600 in parts.
I'll check the scrap yard.
Old Apr 26, 2006 | 09:18 AM
Jimothy12's Avatar
Delimma-
I called around and neither Napa nor Advance Auto has a rear Hub Assembly and told me my only option is to have the dealer do it. Is their another less expensive option? I'm now thinking I might as well get a new car.
Old Apr 26, 2006 | 09:36 AM
MaximaSE96's Avatar
Maxima Owner
haver a dealer order the part....and do the work urself.....and if its a clicking sound it might be an axle....bearings are ususally more of a groaning or humming sound
Old Apr 26, 2006 | 10:28 AM
ChasMan's Avatar
4th Gen Max parts seem to be just available as rebuilts now. Calipers first and now Rear hubs??? Prices seem the same as new from the dealer though.
Old Apr 26, 2006 | 11:36 AM
MDeezy's Avatar
Search car-part.com. Found many places selling it (with ABS) for ~$70.
Old Apr 26, 2006 | 12:12 PM
Jimothy12's Avatar
What a great site. Thank you very much
mvm062
Nov 30, 2020 09:00 AM
maximusrising
Sep 2, 2015 09:55 AM
maxocar
Aug 21, 2015 12:57 AM
classymax420
Aug 6, 2015 06:35 PM
