Gasket on EGR Tube
Old Apr 25, 2006 | 10:37 AM
cguzman's Avatar
Gasket on EGR Tube
long story short I went ahead and decided to change the gaskets on the valve covers and intake manifolds. Little did I know that for a newbie like me I would run into some trouble with the IM plenum. There were so many hoses and I did not label properly
So I gave up when the sun has set. There is tube that the Haynes mentiones to detach. It is behind the IM close to the IACV. The book calls it the EGR guide tube and I believe it holds the some air temp sensor. Well NO WHERE in that stupid book it mentions that there is a gasket there. I did not notice it because of the poor visibility back there and the thing never fell to the ground or I would have seen it. Well after a couple of weeks a neighbor of mine, who is a mechanic, took 5 min to find my stupidity and another 15 to fix it and clean the throtle body and IM. Man I feel like a retard.
I can not find that part in any of the online parts stores. I am to assume it is the same as the EGR Valve gasket? Looks the same but can not tell the dimentions.
Old Apr 25, 2006 | 12:17 PM
speed racer's Avatar
Its called the EGR Guide Tude. There's a metal gasket that connects from the tube to the intake manifold. The IACV has a paper like gasket. Your best bet is to call a dealer and tell him what you need.
Old Apr 25, 2006 | 12:24 PM
motorheadwannab's Avatar
It is a egr valve gasket, i got mine from autozone for like $5 I believe. It was a pain to get to and even worse to install.
http://www.partsamerica.com/ProductL...Gasket&ptset=A
http://autozone.com/servlet/UiBroker...%7ENONE%7C%7EB
Old Apr 25, 2006 | 12:47 PM
cguzman's Avatar
Thanks for the input. My neighbor helped me and I am monitoring if the gasket did not break. If it did then you know replacement is the option. I really do not want to get back there again
Old Apr 25, 2006 | 12:54 PM
BlackMaxdout's Avatar
Here you go....straight from Courtesy Nissan in Tx. $3
http://www.courtesyparts.com/Merchan...ode=14719-A32B
Old Jul 16, 2022 | 11:32 AM
AMnissan's Avatar
Do you NEED the upper EGR guide tube gasket?
Old Jul 17, 2022 | 07:43 AM
JvG's Avatar
JvG
Why are you even asking?
Old Jul 17, 2022 | 07:49 AM
Turbobink's Avatar
You tell us …
Run without for a bit and tell us how things go.
Old Jul 17, 2022 | 11:32 AM
RA030726's Avatar
I'm nutty for Nissans
Red RTV could work, albeit messy.
Old Jul 18, 2022 | 09:22 AM
AMnissan's Avatar
You tell us …
ended up loosening bottom bolts of guide tube to get the right access to slide bolts into upper gasket
knight_yyz
Nov 1, 2015 01:34 PM
Gingerheadman
Oct 1, 2015 05:11 PM
Sep 27, 2015 08:37 AM
JoshG
51
Sep 21, 2015 10:41 PM
