Fuel pump or injectors? Starting problems.
Old Apr 26, 2006 | 07:09 AM
matude's Avatar
Recently I am having problems starting my car only after driving 20+ miles and turning the car off. If I leave the car off for 30 minutes or more, it starts right up. Otherwise, it turns and turns but never fires.
It runs fine while driving and I have never had it cut off, which tells me it is not the fuel pump.
Any body else have this problem with your Max?
Old Apr 26, 2006 | 08:23 AM
95turbo gxe's Avatar
have you tryed to check the fuel pressure. Or tryed to read the ecu for codes
Old Apr 26, 2006 | 08:54 AM
Rated Maxxx's Avatar
I had that problem twice before although not in my max. Regardless both times it was the fuel pump, the car would drive and while im driving poof, it would just cut off so I would check that out if everything else is ok
Old Apr 26, 2006 | 03:38 PM
yeah a friend of mine had that same prblem on his 3rd gen im saying fuel pump.
Old Apr 26, 2006 | 04:25 PM
matude's Avatar
Started up fine all day today. At least I have a little knowledge just helping my brother in law change his fuel pump out.
Thanks for the replies.
Old Apr 26, 2006 | 04:42 PM
its a peice of cake. Just besure to make sure the lines are tight or they could slide off causing no fuel pressure.(the rubber line to the pump)
BkGreen97
Apr 2, 2016 05:47 AM
rnb754
Sep 14, 2015 11:39 PM
aminus21
Sep 12, 2015 04:53 PM
trungg86
Sep 4, 2015 04:58 AM
