HELP with changing rear breaks
Old Apr 26, 2006 | 03:19 PM
tslrock514's Avatar
Hey i just took off the rotors on my rear breaks and i wanted to know how the hell am i supposed to compress the rear break cylinder?! i thought i was just gonna c-clamp it but that sure as hell doesn't look like it is going to work. Someone please help i am running out of sunlight!!!
Old Apr 26, 2006 | 03:27 PM
KiNgJaMEs's Avatar
you have to use a special tool.you can get it from ADVANCE thats where i got mine it looks like a cube it uses a ratchet to screw the piston back in dont us a C-clamp thats what i did and i ruined mine. all u have to do is find the correct pattern on the cube.
Old Apr 26, 2006 | 03:33 PM
ptatohed's Avatar
Licensed to Spell
Please buy a Haynes and/or Chiltons and/or FSM before working on your car.
tslrock514's Avatar
would i be able to get it from autozone?
Old Apr 26, 2006 | 03:52 PM
aussie983's Avatar
You can always try using needle nose pliers and turn real slowly. Be careful or you'll slip.
Old Apr 26, 2006 | 04:27 PM
ptatohed's Avatar
Licensed to Spell
:o)
Yes, for free too. I always use AutoZone's free tool rental service for brake jobs.
Old Apr 26, 2006 | 04:31 PM
ptatohed's Avatar
Licensed to Spell
http://www.autozone.com/servlet/UiBr...3d801f5965.jsp
Fig. 13: A special tool is available to rotate the caliper piston
Fig. 14: As an alternative, a pair of needle nose pliers can be used
Old Apr 26, 2006 | 05:06 PM
Frank Fontaine's Avatar
http://www.thetoolwarehouse.net/shop/AP-7860.html
In my opinion, this is the correct tool to use--it is fool-proof and effective. The price has gone way up (what hasn't) as I paid $34 for mine. But who cares, if the auto parts shops let you rent it for free, why not rent the correct one? My friend got exactly this kit for free rental. You change the fitting and it works for the front as well--way easier to use than a c-clamp, same principle.
Old Apr 26, 2006 | 05:14 PM
lefty
In a pinch, I used the flat end of a file that fitted perfectl in there and used a pair of vice grips to turn it.
Old Apr 26, 2006 | 08:14 PM
tslrock514's Avatar
thanks guys! i have no idea where i would be if it weren't for the org! I actually just went to advanced and got that little adapter that goes on the end of a socket wrench and it worked perfectly!
Huttig2009
Sep 25, 2015 03:31 PM
Jeffesernia11
Aug 23, 2015 06:09 PM
BobMax
Aug 15, 2015 12:35 PM
RealityCheck
Aug 5, 2015 06:18 AM
