DTC's Help
Old Apr 29, 2006 | 03:57 PM
99grnmaxgxe's Avatar
DTC's Help
I got 3 freaking codes popping up.
P1105
P0105
P1705
I did a search and only found that the P1105 had to do with the MAP/BORO Senor, wtf is that? Any help would be great thanks. Any one know anything about the others?
Old Apr 29, 2006 | 04:21 PM
NYC32798's Avatar
You sure those are the right codes? 1105 is improper shifting into 3rd gear and the other 2 come up undefined. Did you get these codes by using a screw driver?
Old Apr 29, 2006 | 04:23 PM
Yeah, that's what I got from the Autozone diognastic check.
Old Apr 29, 2006 | 04:49 PM
Maxima880's Avatar
P0105 Absolute Pressure Sensor
P1105 MAP/BARO Switch Solenoid Valve
P1705 THRTL Pos Sen A/T3
Old Apr 29, 2006 | 04:59 PM
Does that mean that those parts are defective and need replacing? Or is there something else going on.
Old Apr 29, 2006 | 05:17 PM
Maxima880's Avatar
The MAP/BARO Solenoid Valve switches hose connections to the Absolute Pressure Sensor to measure between manifold absolute pressure and ambient barometric pressure for the ECU. These two are connected together by a vacuum line, These two codes are probably related to a common problem. Ruptured, unhooked, or plugged line. Wiring short or one is bad causing the other to throw a code also. The throttle position sensor is probably not related.
ef9
Aug 27, 2015 10:17 AM
eaglclon
Apr 18, 2002 06:36 PM
Soon2BMaxed
Aug 11, 2001 06:32 PM
enticiveblkmax
Feb 12, 2001 06:52 AM
