how long after k&n filter is oiled can i reinstall?
Old Apr 30, 2006 | 08:39 AM
kingrukus's Avatar
no more maxima...
I am in the process of cleaning my k&n filter. After how long can I reinstall the filter after I have oiled it?
Old Apr 30, 2006 | 09:01 AM
Kevlo911's Avatar
Kevlo for President
I wait about 30-45min. Usually I have plenty of time so it just chills outside for an hour or two.
Old Apr 30, 2006 | 09:31 AM
kbmaxima's Avatar
same, i'd clean and oil it at night, let it sit overnight and then pop it back in when I goto work the next morning.
Old Apr 30, 2006 | 10:57 AM
rl2880's Avatar
Be careful to not over oil it. Let it stand up right so any excess can drain. Your fine after 1-2 hours, the longer the better though.
Old Apr 30, 2006 | 11:12 AM
Tim96I30t's Avatar
I have heard horror stories of people over oiling them, oil goes into the maf and so on and ruins evrything. I don't even use the oil I just clean mine out once a month and let dry completely.
Old Apr 30, 2006 | 11:14 AM
Kevlo911's Avatar
Kevlo for President
Yeah, I take an old towel and let some of the excess oil soak in the towel before I install it.
Old Apr 30, 2006 | 11:55 AM
VIP Maxima
if you havent read the directions already, its the oil that keeps dirt away. you might wanna use it next time.
Old Apr 30, 2006 | 07:34 PM
Maxgig's Avatar
I bought a paper filter that I put in for the day when I oil my K&N. After I get home from work I put in my clean freshly oiled K&N and put the paper one in a zip lock bag.
Old Apr 30, 2006 | 07:56 PM
99grnmaxgxe's Avatar
You couldn't wait?!?!?! haha jk
Old Apr 30, 2006 | 08:09 PM
happyricefob's Avatar
V^___^V
i leave it under the sun for 20 minutes and then put it bak on
Old May 1, 2006 | 06:31 AM
Juicey's Avatar
This ORG has saved me $$$$$$$$
According to the directions on the can of oil you buy for the filter it says to leave it at least 30 minutes. It spray's on red so you can see which spots you have sprayed and which you haven't, therefore you shouldn't have to worry about spraying too much oil on it.
Old May 1, 2006 | 06:59 AM
kingrukus's Avatar
no more maxima...
Well, I knocked the dirt out with a brush, then I washed it from the inside out with a hose. I let it dry in the sun for a few hours, then oiled it. I let the oil seep through for about an hour then I installed the filter. I forgot to plug the maf back in and started the car at which point the car threw a code. I immediately shut her down, plugged the maf harness in and it ran fine, but the CEL is still there. I will need to diagnose that tonight.
Old May 1, 2006 | 09:56 AM
99black5spd's Avatar
it probably threw a code because you unplugged the maf, the light should turn off after i think 2 or 3 drive cycles
Old May 1, 2006 | 10:09 AM
Gismo-T's Avatar
B!tch We Got a Problem
Had the same problem w/CEL, after I unplugged the MAF and plugged it back.
The only way to clear the CEL is with a scanner or the ECM.
Old May 1, 2006 | 10:47 AM
kingrukus's Avatar
no more maxima...
Thats exactly what I am thinking too. I will check the code tonight and reset it...hopefully it doesn't come back. I did that with my EGR CEL a while ago and it never came back *knocks on wood*.
Old May 1, 2006 | 11:16 AM
DR-Max's Avatar
Yikes!! The last time I did that (to another 4th gen that I had 8 yrs ago), it did something to the MAF because even after resetting the ecu, the code kept coming back. To make it worse, it was making my car hard-start. Took it to the dealer and they can't find the problem. Then they started blamming it on my aftermarket radio and said that the RCA cables are causing interference to the ECU and making it go haywire...I know that's BS.
matts95max
Apr 23, 2025 10:44 AM
knight_yyz
Nov 6, 2015 02:34 PM
The Wizard
24
Oct 1, 2015 08:47 PM
Maxima Pride '07
Sep 12, 2015 07:29 AM
