grease leacking from from axle
Old May 1, 2006 | 02:35 PM
ukraini9mofo's Avatar
I am planning to lower my car this weekend and I saw that I have grease leaking out of the axle shoulder, so I was wondering is it possible to change it yourself, are there how to's or just go to shop and get it done there, and also should I get it fixed first and then do allignment or allignment doest get messed up in the process of doing this?
Old May 1, 2006 | 03:18 PM
1996blackmax's Avatar
I believe you are referring to the CV boot. If it has been that way for a while, it may be better to just get a new axle. Dirt in the CV joint is not a good thing, and if you have some in there the joint will most likely fail.
Old May 1, 2006 | 03:30 PM
dgeesaman's Avatar
Maintenance Monster
Sometimes a rebooted axle will burp a little grease. But look REALLY closely for cuts, tears, or cracks. If that's the case, you need new boots.
Dave
Old May 1, 2006 | 03:44 PM
matty's Avatar
LEAKING !!!!
Old May 1, 2006 | 03:46 PM
I found mine after washing my car after it had been raining for a while. I was like what the heck is on my rim. Then I looked inside and saw the tear on the CV boot.
Old May 1, 2006 | 04:09 PM
200kMax's Avatar
yes, its a cv boot. if its torn wide open, just get a brand new axle. if not get the boot repaird. should be around 50 bux for a boot. but axle will cost u quite a penny more
Old May 1, 2006 | 05:56 PM
lilonasis's Avatar
Both of my boots have been cracked since February 05. I'll be changing them this week. Here's a good DIY site http://www.motorvate.ca/mvp.php/100
Old May 1, 2006 | 08:17 PM
96blkonblkse's Avatar
one after another in my 5spd. my passenger side ripped before i noticed it was cracked so i just left it ripped in 2 replacing it this thursday, and just yesterday i noticed i ripped my upper boot on the drivers side. so i need 2 driveshafts, luckily i get everything for 50% off (school discount). It should be a temporary fix to my leaking tranny (diff bearing problem).
boomerbrian
Oct 31, 2018 10:25 AM
RealityCheck
Oct 2, 2015 06:34 PM
The Wizard
24
Oct 1, 2015 08:47 PM
Bonka
Sep 14, 2015 11:18 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
