Should i pickup used motor mounts then urethane them or use my broken ones?
Old May 2, 2006 | 04:14 PM
overseaz's Avatar
I searched the org and havent really found the right answer im looking for, but it is basicly this...
I have 3 out of the 4 motor mounts out of my maxima right now, the front and rear engine mounts are totally shot.. its really loose but not totally torn out just torn from the top or side. Have allot of people been going ahead and filling these with the urethane or do they go out and pickup decent used ones then fill them?
And If so where is a good place to pickup a used set on the internet?
Dave
Old May 2, 2006 | 05:31 PM
motorheadwannab's Avatar
i bought poly's from energy suspension and had them pressed in at a machine shop...i love them wouldn't do it any other way.
Old May 2, 2006 | 05:54 PM
matty's Avatar
Buy the front and rear from someone on here, have the polys put in and then installed. Or get the mounts and have the shop press them in and install them for you
-matt
Old May 2, 2006 | 10:38 PM
overseaz's Avatar
-matt
I forgot to add the most important detail... Im auto
ES Poly's no workie for Auto motor mounts.
Old May 6, 2006 | 09:49 AM
overseaz's Avatar
Anyone??
whats the best solution for Auto motor mounts?
mine are shot should i fill them even tho its loose but not broke completely free?
or is it best i get a pair where the rubber is cracked but not totally broken
Old May 6, 2006 | 10:46 AM
BigLou93SE's Avatar
I don't know the condition that my motor mounts are, although I'm expecting them to be bad. I'm just going to end up filling my original ones, unless someone has something to say about the original posters questions. Bump
Old May 6, 2006 | 11:29 AM
GodFather's Avatar
Made in Taiwan
i was going to tell you to call cattman because he sells those ES poly-U mounts ($100 shipped) that you can insert into the bracket. But their mounts only fit the 5-speed versions. You can use your rear bracket to fit one of the mounts from cattman, but for the front, it won't fit because 5speed mounts are smaller than the auto mounts.
Then, you should just try to buy used mounts and fill them up, but I just think it's best to get brand new mounts if possible.
KabirUTA13
19
Oct 17, 2015 02:15 AM
vball_max
Sep 17, 2015 10:01 AM
carid
Sep 17, 2015 05:00 AM
steveyphat
Sep 15, 2015 03:43 PM
QueensMAX
Sep 15, 2015 04:14 AM
