p0306 code
Old May 4, 2006 | 09:00 PM
Russkiy's Avatar
p0306 code
maxima threw a p0306 trouble code. Is it the coil or what?
the car is acting up on the idle lately. feels like a misfire but only on the idle.
Any response is appreciated.
Old May 4, 2006 | 09:44 PM
Blackwind's Avatar
ok this may hurt!!!!
YOU HAVE THE CODE READ THE FAQ'S IF YOU DONT FIND IT THERE (WHICH YOU WILL) THEN COME BACK AND ASK FOR HELP!!!!
Old May 5, 2006 | 07:31 PM
Russkiy's Avatar
so,what is the most common failure with this code, coil or something else?
Is there anyway to check the coil?
If this is the coil failure then wouldnt it misfire constantly? Because it runs fine when not idling.
Old May 5, 2006 | 08:00 PM
Maxima880's Avatar
OK are you sitting down?
P0306 #6 misfire
Possible causes (I don't know if these are listed in order of likelehood)
Improper spark plug
Insufficient compression
Incorrect fuel pressure
EGR valve
Injector circuit open or shorted
injector
Intake air leak
ignition secondary circuit is open or shorted
Lack of fuel
Magnetized signal plate (flywheel)???
Quite a list isn't it
You can check the coil with a multimeter
I'll give you the specifics later if you want them.
Old May 5, 2006 | 08:05 PM
JwaxMax99's Avatar
You own a 99. Buy-install 6 new coil packs and you're done.
Old May 6, 2006 | 12:48 AM
Russkiy's Avatar
I think I found the problem
Thanks for the responses, great help.
Found an air leak today at the intake manifold gasket right at cylinder #6. So, i guess that the problem. I'll replace the gasket and possibly the knock sensor since I'll be right there and then we'll go from there.
Thanks for the quick replies, always appreciated!!1
Yegor
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
