Climate Control Doesn't light up?!?!
Old May 6, 2006 | 01:24 PM
showoff's Avatar
I changed my deck the other day and at night I noticed the only part of the climate control that lights up is the "TEMP" hot/cold button.
Any ideas, is there a wire the left out or is there a problem with the unit??
Old May 6, 2006 | 01:32 PM
Gismo-T's Avatar
B!tch We Got a Problem
I'f you have a problem with the unit, I have one I can sell to you!
Old May 6, 2006 | 01:34 PM
mendon99's Avatar
tastey wheat
did you forget to plug stuff back in? theres 3 plugs in the back, this is assuming you have manual cc.
Old May 6, 2006 | 02:59 PM
maximaSE327's Avatar
same thing happened to me... when i took my dash apart to paint it when i put everything back together my hazard, rear defrost and some of the cc buttons werent lighting up... and slowely over time they all went out, now only the green displace shows up ( i have auto cc)... someone said if u dont disconnect ur battery before disconnecting and then reconnecting all the wires, that it could blow bulbs... so ive been living on that assumption, waiting until i put leds in to see if they work and light back up... im hoping the answer is that simple
Old May 9, 2006 | 08:18 AM
sodie14's Avatar
the bulbs in the digital climate control easily burn out "break" when you do a id/cd install...the vibrations from moving it in and out of the car can sometimes cause the bulbs to burn out. you can buy replacement nissan bulbs, or do an led job on them....and there are tons or write ups on how to do both. i got replacement bulbs for mine when the same thing happened.
Old May 9, 2006 | 12:59 PM
99se5speed's Avatar
SHIFT_up
yeah my digital CC has burned bulbs in various spots. I actually thought that there was 1 bulb going thru a spectrum distributing light to all the buttons. I saw this in a write-up, but when i saw different spots blow i figured that might be older models and the newer ones all have seperate bulbs. Here come the LEDS.
MikesChevelle
Mar 2, 2021 11:32 AM
dr3am
25
Oct 22, 2015 08:53 PM
asianstyle
Aug 24, 2015 08:29 PM
