O/D light is on
Old May 7, 2006 | 03:07 PM
wgray's Avatar
O/D light is on
My O/D light comes on when I start my 1995 Se. When I turn my head lights on it goes off and goes into over drive. When I turn my head lights off it goes the indicator goes off and comes out of overdrive. The othernight I tried flashing my highbeams and the dont work. Whats up
Old May 7, 2006 | 03:37 PM
whitegold's Avatar
Sounds like something is shorted. What happens when you press the O/D button? Does it turn the lights on and off?
Do your high beams work if you put it into high beam mode?
Old May 7, 2006 | 03:45 PM
wgray's Avatar
The O/D button works nomally when the headlight are on. It does nothing when the headlights are off, and I do not have any highbeams at all the headlights just go off when I try to activate th hhighbeams.
Old May 7, 2006 | 04:54 PM
whitegold's Avatar
Check the wires going to the headlights for any damaged, melted wires. Also, you might want to check the actual control on the steering wheel for the headlights to see if there are any shorts.
Old May 8, 2006 | 05:38 AM
clive's Avatar
100% chingon
When you get this sort of problem it is usually an earthing fault. You probably have a disconnected ground wire somewhere. I'd start by checking the harness around the steering column and the plug/socket connectors in that area.
Old May 8, 2006 | 03:01 PM
wgray's Avatar
thanks I will get back let you guys know what the deal is peace
fastcarny
Oct 6, 2015 10:42 AM
bryants95max
Oct 2, 2015 12:52 PM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
dcardello
Sep 3, 2015 11:44 PM
