Knock Sensor
Old May 7, 2006 | 06:40 PM
J_Swaleh's Avatar
Knock Sensor
hey guys. i tried very hard to get my old knock sensor off with a ratcheting wrench. my girlfriends hands slipped right down there and she put the wrench on the bolt, then i tried to untighten the bolt, but it wouldnt budg with theagle i had. ANY suggestions or should i suck it up and try harder? Thanks in advance (TIA)
Old May 7, 2006 | 07:57 PM
GStrength's Avatar
Aight well I forget the size of the bolt, just know all you need is the socket that fits the bolt, a universal joint, and a 10 inch extension. I have dat injen cai, so i removed it to give me some more space. but i just changed mine on saturday for my first try and popped it off in less then 10 minutes, being that your girl got little *** hands it should be quick for her to put it in for you so the job shouldnt take you more den 20 mins. good luck.
Old May 7, 2006 | 08:46 PM
AlpineGt66's Avatar
umm i replaced two knock sensors in less than two weeks and its a 12mm bolt and i dont use an extension or a universal joint. You slip the wrench under the wires and i got bigger hands than most people. What I find helps me is That green sensor you unplug before that i push that braket up a little so i have clearance to go inside with the hand easier! and once the socket and wrench is on i use a piece of wood and use it as a seesaw of the engine to push the wrench to break the bolt loose!
Old May 7, 2006 | 08:50 PM
GStrength's Avatar
man da hell wit dat, its a good stradegy for you, a very big pain in da *** if you ask me. I still suggest the u-joint and extension. that **** just slip right on in without you ever having to reach your hand in anywhere. and i my bolt snapped off easy as hell first try turn and SNAP! it did da trick.
Old May 7, 2006 | 08:57 PM
bds's Avatar
bds
I replaced my knock sensor a few weeks ago and it wasn't as easy as the instructions led me to believe. I tried using the socket and universal joint with no luck. I finally broke it loose with a ratcheting wrench and then used the socket set up to get it the rest of the way out. I still took me almost an hour to get the bold loose. Make sure you put the wrench on with as much play as possible to turn it counter clockwise. Make sure you have a good quality wrench if it has too much flex or play in the ratchet it wont work. good luck
Old May 8, 2006 | 10:37 AM
J_Swaleh's Avatar
Thanks uys. The ratcheting wrench methid was the ticket. I tried the joint and extentions, but just got the socket stuck on the bolt. Anyways, alls well, i won the infamous battle of the ****ing knock sensor.
Old May 9, 2006 | 08:20 AM
vvslavavv's Avatar
I've been trying w/ a u-joint and a 12mm flex-socket ... Can't get the damn thing off, the u-joint just slips .. i guess i'll try the ratchet ... but for those of you that did it w/ a u-joint .. how the hell did you get the angle good enough for it not to slip?
Old May 9, 2006 | 12:03 PM
KaZ's Avatar
KaZ
For me, I took a 1/4" wrench and 12mm socket and places it on the knock sensor... then I think I ended up using a BIG flathead screwdriver to pop it loose... it came right off after that. My biggest problem was my hand barely fit through the opening (even after moving the solenoid away towards the drivers side of the car) and the engine was warm when I did it... so if I held my hand in the wrong spot too long, OW... otherwise, it took about 20 minutes...
Those that can do it in 5 min must have tiny hands...
Old May 9, 2006 | 01:33 PM
GStrength's Avatar
i took my intake off gave me more leverage, used the the u-joint, 10 inch extension and crack it came off in about 5 minutes, putting it back on took about 35 minutes it was harder to put back in
Old May 9, 2006 | 04:49 PM
NmexMAX's Avatar
dot dot dot ...
Your g/f's grip isn't good enough ..
Just take the farkin IM off, it's not that bad you know.
Old May 10, 2006 | 07:01 AM
vvslavavv's Avatar
Used a ratchet and a metal bar to push against the block. Came out in 5 minutes. Installation took another 10min. Thanks for the help guys. I've reset the ECU, the car seems to feel better
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
