B&M Shifter Problem
Old May 8, 2006 | 02:54 PM
MaximaEvolution's Avatar
B&M Shifter Problem
A while ago I installed the shifter myself. The directions were fairly straight forward but I'm feel as though somethins wrong. Everything shifts perfectly but sometimes when I'm slammin' through the gears, I push down and the bushing at the base of the shifter sinks below the shifter mount and is a B*T*H to get it to come back up.
Not only that, I already lost the spring that keeps the shifter centered and had to replace it with some crap autozone spring (dont expect that to last)
Any solutions to my problems? Anythin is appreciated thanks peeps.
Old May 8, 2006 | 07:20 PM
bumpppp please help guys its drivin me freakin nuts
thank you
Old May 8, 2006 | 07:30 PM
konak85's Avatar
reinstall it and make sure everythings tight and tidy
Old May 9, 2006 | 03:05 PM
i dont think it has anythin to do with a loose bolt.. its the bushing itself that drops below the mount. The entire rod drops below and hits the heatshield.
anyone else have any ideas/solutions?
Old May 9, 2006 | 05:26 PM
JeremysBlkMax97's Avatar
Have you looked to see if the bushing is in good shape?
You probably need to disassemble the heatshield, cat/Y-pipe connection and look under there as someone pushes on the shifter and see what the problem is. Cheaper than paying someone else.
If it is the bushing, I recommend the urethane bushing that Larrio is selling in the group deals section. With my B&M, now the shifts are much more defined, and it makes a positive clunk now as it shifts, very good product.
Old May 9, 2006 | 06:02 PM
i dunno its hard to explain... ill try and take some pics this week hopefully that will help. The shifter is brand new i put it in a couple months ago.
Mar 12, 2020 12:06 AM
Robert Schneeweis
Jan 11, 2017 06:47 PM
lux97Max
Sep 28, 2015 11:18 PM
ef9
Sep 10, 2015 10:35 PM
