Can someone help me out on this???
Old Jun 17, 2001 | 11:46 AM
hockeyghst's Avatar
After i got rear ended i realized that my tail lgihts do not work when i turn my head lgihts ons......but the brake lgihts works......but thats not my biggest problem my interior lgiths dont work....like the ones on the door and the dome light and the lights on the roof of the car the push button ones......also in my fuse panel there is a 7.5 fuse that isnt blown but wont work....there r 3 columns of fuses right......and in each column the 7.5 does not work goign in a straight line....so in otehr words there are 3 7.5 fuses right next to eachoter(left and right of the middle fuse) and they r not blown but they dont workk......what od u think the problem could be......NOTE:this happened after i got rear ended......any suggestions???
Old Jun 17, 2001 | 11:48 AM
Ravq's Avatar
The reason why your brake lights work is because it is on a separate circuit then the parking lights. Have you tested them with a multimeter to see if power is running through?
Old Jun 17, 2001 | 12:06 PM
Daniel B. Martin's Avatar
I do not understand what you mean by a fuse which is not blown but does not work. That seems contradictory.
Tail lights are powered through fuse #66 (15 amps) located in the narrow fuse and link box in the engine compartment adjacent to the battery ... and ... fuse #5 (7.5 amps) in the passenger compartment fuse box. Since there is rear-end crash damage in this story you must also look for a broken ground wire in that vicinity. You could use a multimeter to backprobe the bulb sockets to determine which is missing, +12 volts or ground.
