well, my low fuel warning light don't work
I found out the hard way. I wanted to see if the light worked I was pretty sure it was gonna. I was cruising down interstate 294 S. and the engine just died. It was raining and i was stuck there for over and hour. Trucks were wipping past me really fast. The needle was BARELY below E.This is my own fault though regardless
, LOL. I just though the org. would appreciate a story like this.
is there another way to check it? LOL!
, LOL. I just though the org. would appreciate a story like this.is there another way to check it? LOL!
Originally Posted by D-Bo
Why would you intentionally run out of gas?
Everyone i've ever heard of with a MAX, their low fuel warning light doesn't work, knowing this I fill up when it reaches the lower half of the last quarter of fuel, and never let it fall under the E line...or else things could get SH*TTY...
Mr. Wills, you're not banned? http://forums.maxima.org/showpost.ph...&postcount=487
Guess not.
..My needle was no where near the E, and I had no gas in my car
...In conclusion, my car wouldn't start nor do I let my car go under 1/4
I guess you aren't the culprit, anyways don't let your fuel go below 1/4 tank, or you'll put your fuel pump at risk.
I swear mine doesn't work either. I've only let it hit E once, and I really had no choice (lots of evenings working til after gas station was closed) and the light never came on. Luckily I filled up before it was all gone, but still...it would be nice to know the light atleast worked even if I never let it go much lower than 1/4 tank.
That's what i'm talkin about.
my light works but it seems it's like bugging...it's dims in and out but it works. As long as it works i'm happy. Plus i try not to let the tank fall under half (helps on the pockets instead of filling up 70 bucks all the time 30 seems to do it)
mine works on both of mine it comes on when i go up steep hills when im just above empty. just wondering if this is me but i think i have a magical fuel gauge it moves up and down a bit every time. ill have like 100km on a full tank and it will be at like 7/8 of a tank and then it will go back up where it should be right at full.
Originally Posted by maximaintheface
lmao u shoudl have had a can of gas with you if you wanted to check.
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
if you knew you were going to try this, you should have filled up a gas container and brought it along, to avoid potentially getting stranded.
