drivebelt adjuster does not loosen
Old May 15, 2006 | 12:59 PM
delacruz_17's Avatar
im trying to replace my two belts on my 96 but the adjuster doesnt want to loosen. Which way am i supposed to be turning left or right? I do both and nothing seems to be happening. what gives? If i turn left it gets to a point where i can no longer turn. if i turn to the right it gets difficult to turn so i stop cuz i dont want to damage anything. what do i do?
Old May 15, 2006 | 01:23 PM
JNCoRacer's Avatar
Just the tip.
Did you tighten the nut on the pulley first? If not and you tried to loosen the belts, you may have inadvertently stripped the threads.
Old May 15, 2006 | 02:04 PM
JNCoRacer could you paraphrase what you just said my english is not the greatest thing in the world.
All i tried to do was turn the "adjuster" nothing more nothing less. I touched no pullies or anything just the "adjuster".
to my understanding all i have to do is turn the "adjuster" then the belts losen, i then replace the belts then tighten again the "adjuster", the end. ¿am i wrong?
Old May 15, 2006 | 02:08 PM
JNCoRacer's Avatar
Just the tip.
You have to loosen, not remove, the 14mm nut on the tensioner pulley BEFORE you loosen the adjuster. Otherwise it will not loosen and move.
Old May 15, 2006 | 02:11 PM
I turn the 14mm bolts all the way to the left but nothing happens. Am i supposed to do something after turning the 14mm bolt to the left. To my understanding the belts should loosen up and i should be able to replace then from there. I think i am missing a step or something. correct me if im wrong
Old May 15, 2006 | 02:13 PM
JNCoRacer's Avatar
Just the tip.
The pulley has a 14mm NUT that you have to loosen with a wrench from underneath the car before you can loosen the adjuster from inside the engine bay.
Old May 15, 2006 | 02:19 PM
okay i understand. Loosen (not remove) the 14mm NUT of the pulley from underneath the car. next loosen (not remove) the adjuster from the engine bay. I understand.
Just one last question. when you say "pulley" you are referring to the pulling that is part of the "adjuster" correct? the one that is smooth and has no grooves on it, correct?
Old May 15, 2006 | 02:20 PM
JNCoRacer's Avatar
Just the tip.
You are correct sir.
Old May 15, 2006 | 02:21 PM
thank you sir i will get on it right now before the sun sets. thanks once again.
Old May 15, 2006 | 02:33 PM
dgeesaman's Avatar
Maintenance Monster
Check the diagram listed on page MA-10
http://davidgeesaman.com/maxima/MA.pdf
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
