removing iacv
Old May 16, 2006 | 04:41 PM
appleman's Avatar
removing iacv
how is it done. ?
and how should i go about cleaning it
Old May 16, 2006 | 04:56 PM
JwaxMax99's Avatar
Detailed in the Stickies. Look under 4TH Gen. FAQs
Old May 16, 2006 | 05:01 PM
maximaintheface's Avatar
take the 3 bolts out and clean it with throttle body cleaner. take the cap on the bottem inside of it off i think its held on by few screws its been a while since i did mine. i just used a toothbrush and some cleaner.
Old May 16, 2006 | 05:13 PM
JNCoRacer's Avatar
Just the tip.
And make sure you put the gasket back on. Yep un-plug it and remove the 3 12mm bolts securing it to the intake. Should be 3 phillips head screws holding on the brass cup. Clean and put back together.
Old May 16, 2006 | 10:01 PM
ya be carful to make sure the gasket is in all the way i thought it was the first tim i did it and it wasnt and my car ran like poo.
Old May 17, 2006 | 11:53 AM
spiff56747's Avatar
What gasket are you guys talking about? I didn't see any gasket when I cleaned mine...
Old May 17, 2006 | 12:49 PM
ti2tmax's Avatar
Has his VINs memorized
Mine didn't have one, but I bought a used one and it did. There's sometimes a paper gasket there like the one on the Throttle body.
ti2tmax's Avatar
HIGHLY recommend useing a gasket!
Old May 17, 2006 | 01:06 PM
JNCoRacer's Avatar
Just the tip.
My IACV gasket was metal. So was the one on my 96 and my wife's 98.
Old May 28, 2006 | 01:16 AM
96_vqmax's Avatar
There is a gasket there,it's a thin paper with metal kind of gasket,real thin,if you don't see it,maybe cause it stick to neither the plenum side or the IACV itself.
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
