GLE rev limiter thing
Old May 16, 2006 | 07:15 PM
EdgeVetto's Avatar
I have a 96 GLE, so I assumed that I didn't have a limiter. I took the car up to about 120, and all of a sudden the revs dropped and I stopped getting power, just like a governer would do, which annoyed me. Later that day I tried again, got the same result, but kept my foot on the gas. The rpm's came back, and I was able to pass 120 easily until the car maxed out at ~145 or something. What the hell was the drop in RPM's. It happens every time.
Old May 16, 2006 | 07:30 PM
99grnmaxgxe's Avatar
Maybe it's a sign to tell you not to put your life (and others) at risk.
Old May 16, 2006 | 07:36 PM
Apparition's Avatar
Ichiban King
Old May 16, 2006 | 07:38 PM
jman7777's Avatar
hey dont do 145 on the highways in MA i dont want to die.
Old May 16, 2006 | 10:03 PM
maximaintheface's Avatar
i dont think was the limiter prolly just cause our cars dont have the best top end IBTL.
Old May 17, 2006 | 05:13 AM
Black Maxima
Maybe you have a GXE???? And our speedometers only go up to 140 mph.
kthxby
IBTL
Old May 17, 2006 | 06:10 AM
NmexMAX's Avatar
dot dot dot ...
It's not a rev limiter it's a speed limiter.
Old May 17, 2006 | 08:19 AM
EdgeVetto's Avatar
I tested it out because there was some confusion as to whether it was a GXE or a GLE. The guy I bought the car from said it was a GXE, but the code under the vin says its a GLE, so I wanted to find out. I went just over the top of the speedo, so it was ~145. It was around 3 AM, and not a single person was on the road. The fact that I hit the 'limiter' makes me think its a GXE, but then I was able to pass it. Makes me think that I have an ECU issue or something (besides a limiter) Any ideas?
Old May 17, 2006 | 08:58 AM
FunLovinMaxima's Avatar
From: a charming town in Connecticut first settled in the 1600s
how could you buy a car and not know what the trim level is?
and as for the 145mph...
Old May 17, 2006 | 09:15 AM
SPiG's Avatar
SomePsychoGuy
http://f.maxima.org/showpost.php?p=1232397&postcount=23
FAQs FTL.
Old May 17, 2006 | 12:32 PM
Black Maxima
I was going down the busy L.A. traffic one day, cars everwhere. I thought I would hit some top end. I floored it and when I got into 8th gear I noticed I was at 173.6 mph. I thought my car had a rev and speed limiter but I guess not. I have a GXSE, so I don't know if that matters...
Old May 17, 2006 | 12:35 PM
matts95max's Avatar
ok what does FTL and FTW mean..and IBTL..
Old May 17, 2006 | 12:38 PM
Apparition's Avatar
Ichiban King
For the lose..
For the win..
and In before the lock. - In turn stop posting now.
Old May 17, 2006 | 12:46 PM
matts95max's Avatar
ok thats what I thought on the ftw and ftl but didnt have a clue on the ibtl. Thanks man!
Old May 17, 2006 | 04:42 PM
EdgeVetto's Avatar
Originally Posted by SPiG
The car didn't run out of power. I clearly had a sudden drop in RPM's. They dropped from 5500-6000 to 2000 before they caught again. Before the drop I was still accelerating just fine. The O/D trick wouldnt have done anything
I thought I did know the trim was. The guy I bought it from was a retard who knew nothing about cars, so he told me it was a GXE. I later figured out that it was a GLE, meaning no limiter.
Old May 17, 2006 | 05:03 PM
XeroX's Avatar
Hella internets
This has happened to me before, but i believe the culprit was the fact that i didnt have that much gas....Usually when i try to mash in high RPMs like that when im right above E but considerably below quarter tank, it will stuter like that...
Just my .02
Old May 17, 2006 | 05:12 PM
DJ420's Avatar
Bad Mother Fornicator
Yes, I have also noticed this with mine..
If you need to know yer trim, PM me yer VIN and I'll run it for you..
DJ
Just my .02
Old May 17, 2006 | 07:07 PM
EdgeVetto's Avatar
im good, its a GLE. I was not low on gas.
Old May 17, 2006 | 08:53 PM
WhiteMaxima9600's Avatar
You should not worry about it.. I mean really think about it, how often are you going to try to max you car out? As far as I know our cars don't have speed limiters, rev limiter is 6500rpm.
Old May 18, 2006 | 03:55 PM
EdgeVetto's Avatar
I was just thinking that if my ECU was messing my air/gas mixture up or some other general error then I would be losing horsepower everywhere.
Old May 18, 2006 | 05:07 PM
scrhale's Avatar
your car is a GLE ... an implied automatic transmission. Take overdrive off before the car shifts to 4th. In other words, redline that ***** till right before the rev limiter and you won't have that problem at 120 MPH because you will arrive in 4th in the higher powerband
02PearlSE
Feb 1, 2016 12:37 AM
Excalibur23
Oct 13, 2015 04:33 PM
JoshG
51
Sep 21, 2015 10:41 PM
