To those that have done 5spd swap
Old May 18, 2006 | 08:56 PM
darklegend06's Avatar
Hey I found a different parts list from the VQpower.com one.
heres the VQpower one here
And I got this one and pasted it to my word doc.
The ones in red are the weird ones that is not listed in the Vqpower site. Do I actually need those or what are they? I searched the web site and nothing actually came up.
Part - Part Number - Price
5th Gen Clutch - 301002Y904 - 75.55
5th Gen Pressure Plate - 3021089F00 - 82.06
Clutch Release Bearing - 3050241U20 - 24.50
--Support Rod - 34550-40U00 - 42.74
--Control Rod - 34103-40U00 - 72.52
--Hole Cover - 74965-0E510 - 8.87
--Hole Boot - 74960-0E500 - 3.59
--Hole Bracket - 34560-70N00 - 13.61
Socket Assembly - 34553-50J00 - 13.03
Lever Bearing - 34116-50J00 - 4.50
Bearing Seat - 34118-50J00 - 5.08
Lever Boot - 34122-50J00 - 5.08
Return Spring - 34573-40U00 - 4.28
Clutch Pedal Assembly - 46540-40U00 - 36.20
Brake Pedal Assembly - 46501-40U05 - 55.64
Master Cylinder - 3061031U17 - 71.93
H- Connector To Flex Hose - 3085140U00 - 10.22
H- Flex Hose, w/Bracket - 30855-31U12 - 35.42
H-Master Cyl To Connector - 10.22
Slave Cylinder - 3062031U61 - 38.24
Flywheel - 123102Y910 - 182.29
Front Engine Mount - 1127040U03 - 68.16
Tranny Mount - 1122040U12 - 60.28
B&M Shifter - 115.00
AE Shift **** - 32865-4Y910 - 48.97
Drivers Side Axle - 88.79
Clutch Pedal Bracket Assembly - 46550-40U00 - 43.06
Old May 18, 2006 | 09:34 PM
BigLou93SE's Avatar
Clutch release bearing is part of the clutch assembly, and gets replaced when the clutch is replaced. It's also known as the Throwout Bearing. I would say you need this. The others - no clue.
Old May 19, 2006 | 07:36 AM
phatmax95's Avatar
My guess is they mean these:
And the socket assembly is the socket the shifter fits in, which is on the shift rods I sold you. And the other parts come with the trans I am selling.
Although I am not 100% sure it is my best guess.
Old May 19, 2006 | 11:40 AM
Thanks you guys, so which one of the parts list should I follow? The VQpower one or the one I found somewhere else?
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
JonBlz
Oct 5, 2015 06:02 PM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
