where do i find the pcv
Old May 23, 2006 | 05:24 AM
reggaeboyz's Avatar
i wanted to change the pcv valve..but couldnt find it and i want to know is this valve rubber, plastic or metal?...
Old May 23, 2006 | 05:35 AM
Juicey's Avatar
This ORG has saved me $$$$$$$$
I've been wondering the same thing myself. I know it's pretty buried. Perhaps it's an easy part to replace but I've never done it so a write up would be nice. Search turns up nothing.
Old May 23, 2006 | 06:01 AM
scrhale's Avatar
it goes through the top of the rear valve cover. Just follow the tubing on the upper intake manifold. You will have to undo the bracket that holds the tubing.
http://maxima.cardomain.com/ride/254307/2
As you can see if you scroll down a bit, it is very close to the TB. Good luck.
Old May 23, 2006 | 06:10 AM
reggaeboyz's Avatar
awwww thanks that was a hell of a help..
Old May 23, 2006 | 10:13 AM
ptatohed's Avatar
Licensed to Spell
Haynes/Chiltons. $15 each.
Old May 23, 2006 | 10:51 AM
tavarish's Avatar
fwd gone rwd cr00
Stickiesstickiesstickiesstickiesstickiesstickiesst ickiesstickiesstickiesstickiesstickiesstickiesstic kiesstickiesstickiesstickiesstickiesstickiessticki esstickiesstickiesstickiesstickiesstickiesstickies stickiesstickiesstickiesstickiesstickiesstickiesst ickiesstickiesstickiesstickiesstickiesstickiesstic kiesstickiesstickiesstickiesstickiesstickiessticki esstickiesstickiesstickies
Old May 23, 2006 | 12:59 PM
Fr33way™'s Avatar
Wild for Width
So where is it?
Old May 24, 2006 | 05:04 AM
Juicey's Avatar
How did you finally manage to change the fuel filter? I've though about removing the top pipe and then dropping the filter down to remove the bottom one. I figure while the car is on a ramp getting the oil changed this would be the best way.
BTW: thanks for the info on the PCV, this is exactly what I needed.
Old May 24, 2006 | 05:25 AM
reggaeboyz's Avatar
the fuel filter i fine is pretty easy to remove..u dont need a ramp...just stand to the driver side of the car and take it out the holder, unscrew the top screw then unscrew the bottom and ur done...u will need to disable the fuel pump fuse tho
Old May 24, 2006 | 08:18 AM
scrhale's Avatar
To elaborate more on the fuel filter:
1: Pull the Fuel Filter fuse
2: Start the car (it will die ... duh)
3: Start/Crank/Whatever about 3 more times (Ensure there is a minimum amount of fuel in the lines)
4: Open your gas cap (Relieves the backpressure in the lines)
5: Pull those cursed hoses out
There were many s**t's and f-bombs dropped when I changed mine. You can expect your hand to get a fair amount of gas on it when you are pulling the lines off.
bumpypickle
Sep 20, 2015 08:22 AM
pears
Sep 18, 2015 05:25 AM
Vistance
Sep 17, 2015 05:17 AM
adamgalazka
Sep 8, 2015 01:27 PM
