One fog comes on before the other
Old Jun 18, 2001 | 09:15 AM
WaarrEagle's Avatar
I am having some problems with my fogs. When they sit for a while not turned on (say 24 hours) and I turn them on, the passenger side immediately comes on and the driver side takes a second and then slowly fades in. They end up just as bright and after the first time they both immediately come on. I was going to swap relays and see what happened but they had different diagrams on the top and I wasn't sure they could be swapped. I have heard that the same color relays can be swapped? Is this true? What is the problem with my fogs?? Thanks.
Old Jun 18, 2001 | 05:35 PM
maximus75's Avatar
start with basics. Replace the bulbs. There's only one relay for both fogs. If it were bad the would both be effected.
Old Jun 18, 2001 | 05:39 PM
WaarrEagle's Avatar
Thanks for the response. I just thought it might be the relay because I tried to get it out once and pulled pretty hard before I saw the little clips on the side. I will swap the bulbs out and see if it still happens. What is the number on those? I have stock ones now and thats what I want to keep.
Old Jun 18, 2001 | 05:56 PM
maximus75's Avatar
I'm not sure about the part #. Any parts store can match it up. Nissan doesn't make the bulbs. If u still have a prob after that, I would check the surface where the buld seats in the lens. this is where the bulb gets its ground. If it's coroded or dirty, this could be the prob. Also check the connection where the bulb plugs in. Let me know how u make out.
Old Jun 19, 2001 | 07:09 AM
iamit's Avatar
Use any H3's
Old Jun 19, 2001 | 09:21 AM
WaarrEagle's Avatar
The connector was very dirty at first. It was so clogged up with dirt when I first got them that the light didn't even come on. Then I soaked it out with some baking soda and water for a few hours and all this junk came out. It now comes on but that is the side I am having problems with. Could there still be stuff in there or did the baking soda do anything to the connector?
Old Jun 19, 2001 | 09:36 AM
maximus75's Avatar
If there was corrosion on the connector, the baking soda was a good move. It won't do anything for dirt though. I would recheck your connections on the side your havin trouble with. And like I said b4, pay particular attention 2 where the bulb contacts the housing.
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
